Heater Problems
Discussion in 'Ask An Owner Operator' started by FishingTrucker, Dec 7, 2010.
  1. FishingTrucker
    FishingTrucker Bobtail Member
    Nov 12, 2010
    40
    Thanks Received:
    4
    Hello all. The heater works fine in the back of the tractor but there is "NO" heat coming out of the vents in the front. Only cool air blows out of the vents so it tells me that the vents are connected. Any ideas of what I should look at or do to fix this problem? As always, thank you very much and sorry if this is the wrong forum.
    fzj80 Thanks this.
  2. Big Don
    Big Don "Old Fart"
    Sep 8, 2007
    17,996
    Thanks Received:
    35,643
    Utah's DIXIE!
    There should be a filter in your cab heater. Where it is will depend on your truck. Chances are it has never been replaced since the truck was new. These will plug up and block the air flow.
  3. Rerun8963
    Rerun8963 Road Train Member
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    could be one of the doors inside of the heater box is not operating. you need to check for vacuum lines that may have fallen off, or even a control cable to the heater box that may be loose or fell of its mounting. some a'c-heater systems have a vacuum module mounted in front of the heater box, that may be stuck in the closed position. this looks like a round small can.
  4. trucker_101
    trucker_101 Heavy Load Member
    Apr 23, 2010
    941
    Thanks Received:
    639
    Alberta
    There is a valve that adjusts the temp coming out. Depending on your truck make/model is where it will be. My company has a lot of International trucks & this is a problem on most of them.The valve on these is under the passenger seat.
  5. FishingTrucker
    Nov 12, 2010
    40
    Thanks Received:
    4
    Thank you for your responses. It's a 2002 Freightliner. Where will this valve be?
  6. Les2
    Les2 Road Train Member
    Jul 25, 2008
    5,150
    Thanks Received:
    2,288
    kicked back in my lazyboy...
    What kind of FL? Classic?
  7. FishingTrucker
    Nov 12, 2010
    40
    Thanks Received:
    4
    Oops...it is a Century.
  8. Les2
    Jul 25, 2008
    5,150
    Thanks Received:
    2,288
    Sorry don't know anything about them so I'll just guess.
    If there is an access panel under the dash between the seats, take it off and the valve should be on the right side. You should see water lines going to it.
    When you do find the valve, feel the lines before and after. The lines should be hot before the valve and not after if thats the problem.
    FishingTrucker Thanks this.
  9. robbiehorn
    robbiehorn Light Load Member
    Jul 18, 2010
    143
    Thanks Received:
    56
    Axtell,Texas
    Find your heater hoses coming off the firewall under the hood. Follow the hoses to the engine and there should be water shut off valves at the engine side where they are connected to the engine. Make sure the valves are open. Some people close them in the summer so the AC will get colder.
  10. Rerun8963
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    they guy says he gets heat out of the rear heater....not from the front vents.....if the valve under the hood (which i thought about before i answered) was closed, wouldn't that stop ALL flow of circulating coolant...????
    i think it should......
    it might be a control vacuum switch problem (the panel slide controls for instance), a vacuum line off, a vacuum "motor" gone bad.......i think its in the heater box assembly also known as a plenum.
