HELP 2007 Peterbilt endless air dryer cycling
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by terryt, Nov 18, 2021.
  1. terryt
    terryt Heavy Load Member
    Apr 27, 2009
    736
    Thanks Received:
    777
    Replaced air dryer cause it leaking though the purge valve spitter endless cycling. Here is what happening (c15 cat) air will build up to 130 air dryer purge and slowly leak air out the purge valve down to 110 compressor kicks in back to 130 purge just a endless cycle. The new dryer is the same as the old and we went got another purge valve still the same thing. But if you turn the motor off it will hold 130 for two days. Key on with out engine running will hold air. The only way this dryer and the old one leaks air is with the engine running. Also the new dryer came with a new governor. What is cause of this leak down only with the engine running???????????????? Replace air line to governor also.
    Little more back round it a 379 air dryer sit outside the frame behind left steering tire and has 405k miles
  2. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,744
    Thanks Received:
    9,105
    The unloader valve in the air compressor head is leaking. There is a service kit to replace the valve separate from the compressor. Small cover plate top of the air compressor head. 2 screws.
    lwlevens and Flint1 Thank this.
  3. terryt
    Apr 27, 2009
    736
    Thanks Received:
    777
    ok thanks will check it out in the morning and report back
    Goodysnap and feldsforever Thank this.
  4. terryt
    Apr 27, 2009
    736
    Thanks Received:
    777
    Replaced the unloaders but still leaking down replacing the compressor Monday (can't get one before then) that should fix it. Something is not right with it but it is 14 years old.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    Aug 26, 2014
    4,521
    Thanks Received:
    6,581
    If it is a Wabco, that is not pumping oil, I have replaced the head on several with good results. Those also have to be ordered.
    MOBee Thanks this.
  6. terryt
    Apr 27, 2009
    736
    Thanks Received:
    777
    Yes it is the head been replaced before. Because of age we just went a whole new compressor
  7. Lyle H
    Lyle H Road Train Member
    Apr 16, 2014
    1,291
    Thanks Received:
    2,938
    Before replacing the compressor, make sure the line from the governor to the air drier isn’t leaking.
    This would cause the compressor to cycle like that.
    lilillill and MOBee Thank this.
  8. terryt
    Apr 27, 2009
    736
    Thanks Received:
    777
    Well we changed the compressor and that was not the problem . After much searching we tried hooking up the computer to the ecm and turning on the fan cultch with the computer and found the fan hub had a big air leak. We couldn't hear the leak with the engine running see the ecm only supply air to the fan hub once the motor has run for 30 seconds. This air leak is what is causing it to cycle all the time.
    BoxCarKidd and lilillill Thank this.
