HELP!!! AC/Electrical problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat nip, Feb 6, 2010.
  1. Cat nip
    Cat nip Light Load Member
    Jan 17, 2010
    192
    Thanks Received:
    10
    Magnolia, TX
    Ok I Bought an 05 379 pete about 2 months ago. When I bought it the sleeper AC worked great. Soon as I get it home nothing. Won't blow. Tested line, no power to blower, switch in sleeper doesn't light up. If i have the bunk AC switch on up in front of the truck it turns the whole ac system on (when main ac switch is off and bunk ac switch is on it still blows cold). A Few weeks ago on a warm Texas night i had the truck idling with the ac on and I woke up freezing, the bunk ac was working. It just came on in the middle of the night. It worked all day until I got my wife into the truck to show her how it was miraculously working again and BAM, it hasn't worked again ever since. Anyone know what the deal is???
  2. Cat nip
    Jan 17, 2010
    192
    Thanks Received:
    10
    Magnolia, TX
    Where are our board rocket scientists???
  3. Cat nip
    Jan 17, 2010
    192
    Thanks Received:
    10
    Magnolia, TX
    No electrical guys?
  4. beltrans
    beltrans Medium Load Member
    Nov 26, 2008
    441
    Thanks Received:
    101
    spokane wa
    Could be something wife related.:biggrin_25524: Just joking
  5. cumminswillie
    cumminswillie Bobtail Member
    Jan 30, 2009
    8
    Thanks Received:
    richfield WI
    Check for an a.c. relay in fuse box by clutch pedal or behind the panel in the bunk. Also check for wires that got pierced at the factory by a screw on assembly. There used to be some fuses behind the panel as well. You could also have an issue with the switch up front not making a good contact to signal the relay
  6. cdub304
    cdub304 Light Load Member
    Dec 7, 2009
    162
    Thanks Received:
    68
    Rockford,IL
    Check the resistors in the dash behind the ac/heater controls. Intermittent works sounds like a loose wire or loose connections some where check under the bunk at the heater cool to make sure everything looks cool and check resistors on switch in the bunk as well. Keep us posted
  7. kalh7
    kalh7 Light Load Member
    Mar 28, 2007
    186
    Thanks Received:
    62
    southern illinois
    had the same problem before. was the bunk ac relay in the fuse box.
  8. Cat nip
    Jan 17, 2010
    192
    Thanks Received:
    10
    Magnolia, TX
    changed the relay in the fuse box by the clutch. There is one in the bunk somewhere??? You know how the bunk ac button lights up when u turn it on? mine isn't doing anything. If I turn the bunk switch on up front it turns the ac system on just not in the bunk.
  9. Longhood379
    Longhood379 Medium Load Member
    Nov 30, 2009
    389
    Thanks Received:
    125
    Cremona AB
    Check www.supermiller.com go to the right side of the page and down to schematics, once you have the wire numbers the plugs for the sleeper wires should be behind the glove box at least they were in the older trucks
    Cat nip Thanks this.
  10. Cat nip
    Jan 17, 2010
    192
    Thanks Received:
    10
    Magnolia, TX
    That's what I told her!!! It's all her fault!
