HELP, steering shaft will not slide into housing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Aug 17, 2020.
  1. TowHaul
    TowHaul Medium Load Member
    Mar 7, 2016
    416
    Thanks Received:
    79
    my steering shaft must have rusted or been this way since i bought the truck. I finally just got the cab air bags to work and as a result i could not turn the steering column. I think found out the steering shaft is not sliding into the housing... appears rusty on the outside and boot shaft is missing. A new shaft is about $1,000 and i really want to try out my new air ride. Any advice at all on how to get the corroded shaft to slide in and out of the housing? i tried hitting it with a mallet (after removing from the gear box) and managed to just fkn damage the ujoint. I tried pulling it out with a strap and who knows what the hell i bent (probably nothing). I have saturated the shaft with penetrating oil but it hasnt helped. Not sure what to do next. I barely was able to pry the ujoint off the gearbox... now it will not go back on as i had to use a pry bar to get it off. 118003099_337875837599810_3479907723402415792_n.jpg
    Rideandrepair Thanks this.
  2. Rideandrepair
    Aug 8, 2015
    17,433
    Thanks Received:
    56,542
    Did you grease it good? Should be a fitting near the boot. Maybe if you turn the wheel, so the fittings on top, take grease fitting out, spray pb blaster in it. Pb breaks up rust. Maybe try slick 50 grease. Might have to take the column out, to get the Pb to penetrate. But I think if you keep spraying and prying it, while turning the wheel, it might break loose. U-joints damaged, no big deal. If you get it loose, make sure the other, U-joint under the dash is good.
    TowHaul Thanks this.
  3. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    the crazy part is i cannot find a grease fitting, just 2 holes in the housing (i sprayed pb in one of those holes a few hours ago..none of it ever dripped out and have not tried pulling/pushing) any other tips or tricks? (HEAT?) i barely pried the ujoint/steering shaft off of the gear box but now cannot get it to go back on, or get the shaft to slide into housing (or out). Not sure what my next move is.... good advice on checking the other ujoint..ugh
  4. Rideandrepair
    Aug 8, 2015
    17,433
    Thanks Received:
    56,542
    It’s just rusted, and probably jammed sideways a little now. I’d just keep spraying it, and hammering on the shaft, down a bit, so not to damage the sliding action. Heat maybe? Boots already gone. I don’t know, might be some plastic bushing inside. Might melt it? I don’t know. But if you got the column out. Stand it up, pb blast it, and smack it with a good hammer. I think it’s jammed, now. The holes aren’t for grease fittings? Or broken fittings? I think maybe the fittings on the boot, grease goes in through the two holes. Maybe a little heat, yellow map gas torch.
  5. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    thanks, not sure what else i could do
  6. Zigzag777
    Zigzag777 Medium Load Member
    Mar 25, 2013
    460
    Thanks Received:
    514
    Down Yonder
    Find a local machinist, I can see from your post, that you’re shooting in the dark, and possibly damaging the shaft. A good shop can take a few thousands of an inch, off the shaft. That might be the place to go for the fix. They might be able to recommend another shop who works on this.
    You obviously lack the skills and knowledge to work on the shaft. Go around to a few shops to check labor rates, plus parts. Don’t cheap out on anything that’s safety related.
    Rideandrepair and TowHaul Thank this.
  7. Rideandrepair
    Aug 8, 2015
    17,433
    Thanks Received:
    56,542
    Well, if you can’t break it loose, you’ll need to remove the whole column anyways to change it. When it’s out, I think you can get it to loosen up, with a big hammer, block of wood to protect the end of the shaft. Clean it up with a drill motor, and wire wheel. Grease it up good, make sure it’s not a sloppy fit. A new boot, grease fittings.
  8. lester
    Jan 2, 2012
    2,931
    Thanks Received:
    7,925
    NW, Iowa
    Just grab the end of the shaft in one hand and pull and hit the collar just above the knuckle with the biggest hammer you can swing. It'll come loose, if you were able to pry it up you can knock it down. Get it pulled out and wire brush it real good before sticking it back in. Usually the grease fittings are on the end of the top half of the shaft in the collar. Anywhere else and there wouldn't be clearance for threads and the shaft to slide. Ive had to knock loose more pto shafts on the farm than I can swing a hammer at
  9. LameMule
    LameMule Road Train Member
    Jan 19, 2020
    1,148
    Thanks Received:
    7,418
    Montana
    I was almost certain that you were teasing him with: "Grab the end of the shaft in one hand" but then I continued reading and realized it wasn't a joke.
  10. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    "Just grab the end of the shaft in one hand and pull and hit the collar just above the knuckle with the biggest hammer you can swing. It'll come loose, if you were able to pry it up you can knock it down." i put a strap on the ujoint (dumb) and was pulling while hitting the shaft right above the collar and nothing happened (yesterday). i was able to pry/hammer it off of the gearbox yesterday. what exactly should i do today differently?
