Help with Cobra 29 SWR/Antenna Light
Discussion in 'CB Radio Forum' started by ChickenChops, Oct 30, 2011.
  1. ChickenChops
    ChickenChops Bobtail Member
    Oct 30, 2011
    6
    Thanks Received:
    My Equipment:
    Chevy Silverado 1500
    Cobra 29 LTD CHR
    3' Firestik II Antenna Kit w/ spring, 18' RG-58 cable, and vertical mount; Model FS3-64A8A-B
    Problem:
    High SWR readings on the meter that is built into the radio and the antenna light on the radio comes on when the mic is keyed. SWR reads at about 2 on channel 20 and about 3 on channels 1 and 40. The antenna light comes on on channel 20 sometimes and always when I talk into the mic. When I turn my engine on SWR readings go up even more.
    The radio and Firestik kit are brand new and everything seems to be working fine except I can't lower my SWR. How do I lower my SWR to around 1 or 1.5 and keep the antenna warning light from coming on?
  2. Mr Bee
    Mr Bee Bobtail Member
    Apr 13, 2011
    32
    Thanks Received:
    14
    Midland Ontario
    You would be wise to have it checked with a proper SWR meter. It could be something as simple as a poor ground. Where did you mount the antenna?
  3. ChickenChops
    Oct 30, 2011
    6
    Thanks Received:
    That's probably what I will do next but would like to fix the problem without spending anymore money if possible. I grounded the antenna using 18 gauge wire and will probably replace it with 12 gauge if I can't find any other issues. The antenna is mounted about 6 inches behind the cab on the bedrail (passenger side). About half the antenna is above the top of the cab.
  4. mike5511
    mike5511 Road Train Member
    May 15, 2011
    3,140
    Thanks Received:
    1,523
    NW Arkansas
    Ideal place to mount antenna on bed is about 2ft behind cab. You can get away with mounting right behind cab sometimes, but in all the instances I can remember the antenna used was 4 - 5 ft long. So if you don't want to spend anymore money, first use a good SWR meter or antenna analyzer to see where you are really at and then go from there. It won't cost anything but time to move the antenna. FWIW, even if you get a good SWR reading out of your 3ft antenna, don't expect great performance from it. Like a lot of things in life, when it comes to mobile CB antennas, longer is better. Also, running a ground wire will not overcome the lack of an RF ground. If you determine no matter where you mount your antenna on your bed, your SWR is still high, it is because your bed is not grounded good to the rest of the vehicle. A simple ground wire will not solve this problem. Braided ground straps are the answer. The wider the braid the better. I would first try (because it's easier) a braid strap from the bed to the cab. Be sure and shiny up the metal where you connect. Once your connections are determined to me permanent you can spray them with paint or some undercoating stuff to keep them from rusting. The other choice that I have seen work is a braid strap on each corner of the bed to the frame. Good luck, this stuff is mostly trial and error, but if I was going to go to this much trouble, I would want a 4 - 5 antenna. However if you get the 3ft antenna all matched up good you should be able to go to a longer antenna later without any problem.
  5. ChickenChops
    Oct 30, 2011
    6
    Thanks Received:
    Thanks for the help. I'm still concerned that the antenna warning light lights up when I speak (and occassionally when I don't) and that the SWR jumps when I start my engine (assuming the built in meter works right). Will mounting and grounding the antenna better eliminate this? I'm afraid the light will still come on with a low SWR (assuming the light isn't set too sensitive; does it only light up based on SWR?).
    Edit: I might try a 4' antenna in the same spot tomorrow.
  6. mike5511
    May 15, 2011
    3,140
    Thanks Received:
    1,523
    NW Arkansas
    Do not trust the built in SWR meter. It is good for a reference only. i.e. get a good meter and check your SWR. When it is adjusted where you want it, check the built in meter to see where it is at. That will give you some idea of where your SWR is at without hooking up an SWR meter. The meter in the radio can go out of adjustment fairly easy however. It is not a good idea to trust your radio to a "built-in" SWR meter. It should be checked regularly (every six months or so) corrosion and loose connections can change it very easily. If your lite is coming on you most likely still have too high of an SWR. I haven't talked on a Cobra in a while. I forget what the lite is supposed to do when you key up. Don't worry about the lite if the SWR checks good with an independent meter.
  7. bossboy2
    bossboy2 Light Load Member
    Aug 20, 2011
    264
    Thanks Received:
    60
    Houston, TX
    ChickenChops, before you start spending a whole bunch of money on trial and error stuff, go to a good truck stop where there's a CB shop and talk to the guy. It'll be much cheaper in the long run if you let them take it from there. I say this because I have the cheapest little Midland CB money can possibly buy...I also have a dual Wilson 2000 antenna set-up done by a CB shop guy. It works better than anything I've bought yet.
  8. mike5511
    May 15, 2011
    3,140
    Thanks Received:
    1,523
    NW Arkansas
    That's good advice if you don't have access to a SWR meter. (and know how to use it.) Your point about a good antenna and cheap little radio is also correct. The biggest, fanciest radio in the world won't overcome an imperfect antenna set-up. I re-read his post and the part about the needle jumping when he starts his motor tells me he needs to find somebody with a little CB knowledge to give him a short lesson on how the thing works.
  9. ChickenChops
    Oct 30, 2011
    6
    Thanks Received:
    Good news and bad news,
    Good News: I bought a SWR meter. Channel 20 SWR is now at 1.2-1.3 after unscrewing my antenna's tuning tip a little. Channel 1 and 40 are at about 1.8.
    Bad News: With SWR meter hooked up the antenna light goes on when on channel 1 despite a reading of 1.8. With SWR meter not hooked up the antenna light goes on when on channel 40 despite a reading of 1.8.
    Hmmm....channel 20 seems to work fine so maybe this will work for now as long as I stay around channel 20 (and possibly 1?). Thank you all for your help thus far.
  10. ChickenChops
    Oct 30, 2011
    6
    Thanks Received:
    Is this because the needle should jump to a higher reading (and stay there) when the engine is started or because I have something hooked up wrong? Thank you for your help.
