help with my drive tire choice
Discussion in 'Ask An Owner Operator' started by heavyhaulerss, Apr 10, 2013.
  1. heavyhaulerss
    Dec 23, 2009
    3,723
    Thanks Received:
    2,040
    AL/TN BORDER
    I will have new drives put on within the next 2 weeks. whatever I put on will stay on until they wear out, so I want what I need. not sure on what I should get, but I did narrow it down to 4 type tires. I went to the loves last week cause they had a great deal on d.c. but found out the loves are not carrying d.c. anymore & that was the reason for the sale. all they had left was 3 tires not my size or application.
    I have considered r.r. tread depth, price e.t.c where I run. e.t.c. & came to 4 to consider.
    1 is b.f. dr444 drive lug 38/32 tread r.r. 141
    2 is b.f.st244 steer 18/32 tread r.r. 102
    3 is yokohama ty577 drive lug 30/32 tread r.r. 132
    4 is toyo m657 drive lug tread 28/32 r.r. 106
    4 is my choice with the lowest r.r. of any lug I know of & a decent tread for long life. they are all basically the same price. I have tried different tires over the years. the ribbed, or steer gave me the best ride with the best m.p.g. but lasted about 150,000-170,000 miles while the lugs as I have now last over 300,000 miles, but cost in fuel mileage but they resist more punctures. tires are too expensive to put on & then say, oops wrong one's, I need to buy different ones. when they go on they will stay on. my current kelly kda's gave me great life, but I will never buy them again. 145 r.r. & the worst part is they bounce worse than anything. I think my choices are just personal preference, what I am asking is this..... does anyone have experience with any of the 4 ? good or bad, that would help me make my decision, or eliminate one from the list.? I am not considering michelin. they just cost too much. as far as the terrain I run. it is all interstate 99 % 400 miles a day. into & out of steel mills. thanks for reading & any advice.
  2. CbarM
    CbarM Heavy Load Member
    Jan 17, 2011
    894
    Thanks Received:
    247
    Irvine, AB
    Do you haul alot off road or why are you seeking an all lug pattern? You can get much lower rolling resistance if you can go with a closed shoulder drive tire...
  3. leftlanetruckin
    leftlanetruckin Road Train Member
    Mar 12, 2009
    3,607
    Thanks Received:
    3,163
    Mo Via Blackpool,Lancs.
    I have always had good luck with the Bridgestone 726EL drives. Not tried any on your list though sorry.
    Martin
    MJ1657 and buddyvuk Thank this.
  4. rollin coal
    rollin coal Road Train Member
    Mar 29, 2008
    13,280
    Thanks Received:
    26,787
    TN
    TY577 is a closed shoulder design with deep lug treads inbetween the shoulders. I've got a set of those on right now that I bought new. They've got 200K miles and I might get 250K out of them possibly 300K but I dunno. I did do a lot of high speed heavy loads the first 100,000K miles with them and I'm sure 70+mph speeds will wear tires out quicker than 65 or slower... Now I do 65mph or slower but it's a little late to save the tread life... They're not terrible tires, one or two of them have some slight wierd wear in the lugs but overall not that bad. I don't like them though, due to the irregular wear on those 2, and plan on something different next time. Actually intending to do the opposite as you and go with Michelin or Goodyear. You get what you pay for with drives and from what guys are saying on here about Michelins they actually have a lower cost per mile over the life of the tire.
    heavyhaulerss Thanks this.
  5. heavyhaulerss
    Dec 23, 2009
    3,723
    Thanks Received:
    2,040
    AL/TN BORDER
    I do not haul off road. the deep rubber just last longer & over the last 3 years I have pulled out so many objects out of my tires that would of would of went all the way thru if I had less tread depth.
  6. heavyhaulerss
    Dec 23, 2009
    3,723
    Thanks Received:
    2,040
    AL/TN BORDER
    I have considered, but the price is much higher plus the r.r. is too.
  7. Colorato
    Colorato Road Train Member
    Feb 22, 2011
    1,336
    Thanks Received:
    865
    Bridgestone M720 rr 110
    Goodyear G305 fuel max rr 106 - these are what's on my truck. There wearing great. 113,000 miles and there at 18/32
    And the Michelin XZA3 energy is a 94 but I think it's ribbed only.
  8. LBZ
    LBZ Road Train Member
    Oct 22, 2008
    1,771
    Thanks Received:
    1,266
    Road to Nowhere
    Bought four Michelin XDN2's at Loves Nov. 30th 2012 & they still look new. Granted they are not old or have a hundred thousand miles on them, but have no odd or peculiar wear. Honestly cannot tell they have worn at all. Ride improved over the several year old B/stone 726's, but those things were dated back to 2006 mfg date. Will buy four more XDN2's in the coming weeks unless there is a fire sale on anything else comparable.
  9. Jseney12078
    Jseney12078 Light Load Member
    Nov 1, 2012
    145
    Thanks Received:
    100
    Gloversville, NY
    Michilen XDAE I've pushed 430k on them, lowest rolling resistance on the market at 93. However without a national tire discount or any discount. The price straight up per tire is around 700. Michilen is going to be introducing airless tires for all vehicles next year. The problem with them, first time users need to buy rim and all. Rim flexes, looks like the vehicle is floating on air as it goes down the road, have no idea what the price is. I was watching demonstrations on line with excavators and sports cars. When tire becomes worn down, they just run another band around the rim and your good to go. Solid rubber tire will run cooler, brakes cooler, cheaper, and no issues with air pressure. I can't believe how much rimm flexes, The excavator was running over boulders and the rim just flexed around it. Demonstrated a sports car driving up steps and again the rim flexed to the step. These tires are targeted to it the market for all vehicles spring of 2014.
    BlackLions Thanks this.
  10. heavyhaulerss
    Dec 23, 2009
    3,723
    Thanks Received:
    2,040
    AL/TN BORDER
    AIRLESS TIRES ? yeah I tried them. had them on my tricycle many decades ago. rode real rough, felt every bump.
