Help With the Physical Exam
Discussion in 'Questions From New Drivers' started by kctrucker, Jul 24, 2008.
  1. kctrucker
    kctrucker Bobtail Member
    Jul 10, 2006
    Thanks Received:
    A pinched nerve in my neck has made my left arm considerably weaker than my right arm. In fact, I've failed the lifting test at Swift and JB Hunt. Actually, JB Hunt doesn't require lifting above the shoulders anymore and I think my left hand could've held on long enough to have carried the 100 lb weight around the room...maybe. I didn't even get the chance because the therapist doing the testing stopped because of my left hand squeeze strength (or lack thereof, I should say).
    Does anyone know of a company that does not do the lifting test other than Werner and PTL? I hear most companies now do lifting tests even for van drivers.
  2. cajun
    cajun Light Load Member
    Dec 23, 2007
    141
    Thanks Received:
    10
    USSA
    you'd better go have an MRI done on your neck, i thought the same thing. turns out it was a ruptured disk and 3 more that are bulging, getting geared up for neck surgery now.
  3. Lurchgs
    Lurchgs Road Train Member
    Feb 13, 2008
    2,122
    Thanks Received:
    308
    Denver, CO
    there's a bunch of companies that don't have their own physical.. probably a majority of them, is my guess.
    If you can pass the DOT physical, you should be good to go.
    However, part of the DOT physical is arm strength (pressure up/down against the doctor's hands). I don't recall if I had to do a grip test.. and I'm too lazy to crawl into the back of the truck and pull out my FMCSR.
    I do know that part of the test can prevent you from getting your medical card.
  4. Tip
    Tip Tipster
    Mar 18, 2006
    2,294
    Thanks Received:
    292
    ON STRIKE
    Forget trucking until you get this problem taken care of. You may need surgery. One thing you can count on--it won't get any better. It'll stay the same or get worse. Besides, knowing going in you have this problem may set you up for disaster later if and when you have to file a workmen's comp claim for it. No company will appreciate having to cover claims for a pre-existing condition.
  5. munrkr
    munrkr Medium Load Member
    Dec 14, 2006
    375
    Thanks Received:
    27
    Many companies have farmed out their physical testing to companies like workwell, etc. which are much more stringent than regular D.O.T physicals. Wish I could be of more help...
