Help with Verizon Mifi
Discussion in 'Cellular - Voice - Data' started by Seebs, Sep 12, 2011.
  1. Seebs
    Seebs Medium Load Member
    Mar 4, 2011
    665
    Thanks Received:
    271
    Hey,
    The Verizon Mifi just had a firmware update. To install the update, you need to connect your mifi to your computer via a usb, problem is when I connect it my computer won't install the drivers as it says I 'need a CD' when the MIFI does not have one.
    I have to update the firmware because if you don't Verizon logs you off every 5 minutes.
    Any suggestions on this? There customer service is useless.
    I have the Verizon MiFi 4G 4510L. Computer is a Dell laptop with Windows Vista.
  2. MrMustard
    MrMustard Road Train Member
    Dec 11, 2008
    1,003
    Thanks Received:
    529
    Dayton, Ohio
    They usually put the drivers in a memory card mounted and hidden inside the device. When you plug it in, Windows is supposed to pull the drivers out of the usb drive that gets mounted when you plug it in. Don't know if that info helps, but I'm pretty sure that's what's supposed to happen.
  3. MrMustard
    Dec 11, 2008
    1,003
    Thanks Received:
    529
    Dayton, Ohio
    Seebs Thanks this.
  4. Seebs
    Mar 4, 2011
    665
    Thanks Received:
    271
  5. CondoCruiser
    CondoCruiser The Legend
    Apr 18, 2010
    19,726
    Thanks Received:
    18,734
    Tennessee
    Most customer services are useless ;)
    MrMustard Thanks this.
  6. MrMustard
    Dec 11, 2008
    1,003
    Thanks Received:
    529
    Dayton, Ohio
    I got the answer over at evdoforums. If you ever need help with that sort of thing, that's the place to go.
    Mark Kling and Seebs Thank this.
  7. slowpoke89
    slowpoke89 Road Train Member
    Oct 10, 2011
    1,085
    Thanks Received:
    458
    Slowpoke land
    i had an hp laptop with vista and had a few prob lems with the mifi software, then after switching to a dell with windows 7 i hadnt had a problem since. VISTA SUCKS!!!!
  8. tirednaz
    tirednaz Heavy Load Member
    Oct 4, 2011
    838
    Thanks Received:
    430
    Arizona
    Vista is the big issue with a lot of software updates.
  9. Gazoo
    Gazoo Resident Mental Patient
    Apr 14, 2007
    626
    Thanks Received:
    56
    Bedrock
    Guys, I am a Verizon Wireless rep and will be more than happy to answer any questions if you dont want to deal with cust svc. You can shoot me a PM and I will give you my email and phone number to help you out.
  10. eastcoastguy1975
    eastcoastguy1975 Light Load Member
    Dec 6, 2010
    245
    Thanks Received:
    14
    hampton,nh
    im a long time verizon customer and i'd like to know whats the cheapest way to get connected to internet on my laptop while mobile? i just think $30 or $40 dollars a month is to much when all i want to do is pay bills and check email and i want it on laptop not phone.
