HELP!
Discussion in 'Questions From New Drivers' started by onil rosario, Feb 14, 2016.
  1. onil rosario
    onil rosario Bobtail Member
    Feb 14, 2016
    5
    Thanks Received:
    I work OTR and my friend is giving an opportunity to work local on one of his truck pulling containers 50/50 out here in kearney NJ, what advice can u give me,
  2. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    Aug 1, 2009
    1,412
    Thanks Received:
    1,186
    Columbus, OH
    Learn Spanish, Russian, and whatever they speak in the Middle East and you'll be fine.
    thejackal and Straight Stacks Thank this.
  3. Lonesome
    Lonesome Mr. Sarcasm
    Dec 15, 2007
    11,189
    Thanks Received:
    22,979
    Northern Indiana
    get used to flat tires, junk chassis, non working lights, hours looking for your unit, etc.
  4. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    75,015
    Thanks Received:
    171,043
    Henderson, NV & Orient
    And looking for decent paychecks. Of course what a decent paycheck is, is subjective.
  5. Mudguppy
    Mudguppy Degenerate Immoralist
    Apr 28, 2014
    1,657
    Thanks Received:
    4,064
    Wooley Swamp
    Go for it.
    Working for a friend never causes any problems......
    Diesel997, TripleSix, Lepton1 and 2 others Thank this.
  6. RogerThat72
    RogerThat72 Road Train Member
    Jan 30, 2014
    1,787
    Thanks Received:
    995
    Get ready to be treated like absolute scum of the earth. Port works talk down to you like your nothing but scum.
    Chinatown and MooneyBravo Thank this.
  7. MooneyBravo
    MooneyBravo Heavy Load Member
    Feb 20, 2012
    853
    Thanks Received:
    1,216
    Vermilion, Oh
    I did containers many years ago and was in and out of Dundalk Marine terminal in Baltimore. There are pro's and cons to every job. You do want to inspect your chassis before leaving the yard. Make sure that everything is up to speed i.e. tires, lights etc. Because once you leave the yard, it's your baby or the company that you drive for. You may only need a signature to get out of the yard but those scum bag union people will give you no sympathy when they are going on break or it's quitting time. If you show up with a flat bed that needs to be unloaded, they will charge you boo koo $$ to do it too.
    Chinatown Thanks this.
  8. onil rosario
    Feb 14, 2016
    5
    Thanks Received:
    thankz to all the advice posted. I got a feeling that it would be best staying OTR.
  9. ajohnson
    ajohnson Medium Load Member
    Jan 6, 2016
    580
    Thanks Received:
    1,368
    chicago area
    That depends on differant factors. The mist important bring if your happy where you are. What your longterm goals are, and What your priorities are. Obviously if hometime is top priority go for the local job.
  10. Raezzor
    Aug 1, 2009
    1,412
    Thanks Received:
    1,186
    Columbus, OH
    Like AJ said, if it's hometime you are looking for the port work might be the best option. It depends really. For me, I absolutely despised going into the ports. Railyards aren't much better. There's just too much of the "hurry up and wait" mentality going on there, and with the unions in there NO ONE will help you unless they are customer service types, and even then it ain't always easy to get them to do their job. If you don't know where to go or what to do you are pretty much SOL until you do. It can be a real trial by fire. But once you get the hang of it it's mostly just a waiting game. Waiting to get into the port, waiting to get a spot to get the can off, waiting in line to get inspected to get out, waiting for the inspection, etc etc.
    And if you think I was kidding about learning other languages, I once had a check-in person on the phone at Global in Bayonne, NJ thank me, in a VERY exasperated voice, for speaking English. That after sitting in line for 30 minutes with 1 truck in front of me to check in. Usually takes 2-5 minutes to check in. :)
