horn beeps after shutoff.
Discussion in 'International Forum' started by Scorcher21, Sep 22, 2012.
  1. Scorcher21
    Scorcher21 Light Load Member
    Apr 20, 2011
    146
    Thanks Received:
    141
    Crossville Tn
    been driving a prostar for over a year now. well, 3 actually, two 09's and an 08. and occasionally after I shut of the truck and get out the horn starts going off. 99% sure I'm always in neutral before I pop the brakes and step out (yes its an auto) and always at least turn the main lights off. Sometimes it starts right when I get out of the truck and sometimes it waits till I'm halfway across the parking lot. Not a huge issue except it really is annoying, my question is what is causing it? Something I'm unconsciously doing, or even yes, I have thought this, am I doing things to quickly, stop neutral pop brakes out of the truck in a couple seconds.
  2. Bullet15
    Bullet15 Bobtail Member
    Aug 15, 2012
    22
    Thanks Received:
    13
    Hanover, PA
    Could be a bad ground connection. I'd check that first, simple problem simple fix.
  3. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,773
    Thanks Received:
    6,211
    Make you select neutral, set your parking brake, then key off, if not the horn gets mad.
  4. Scorcher21
    Apr 20, 2011
    146
    Thanks Received:
    141
    Crossville Tn
    three different trucks. at least the two '09's did/do it. only had the '08 couple weeks b4 the trans went dont recall if it did that also in that time span.but my point being sounds more like some preprogrammed alarm/warning thing. just curious as to what that alarm/warning is so i can avoid doing it in the future.
  5. Scorcher21
    Apr 20, 2011
    146
    Thanks Received:
    141
    Crossville Tn
    pretty sure thats the way I do it..... would setting the brake before neutral effect it, I guess its possible I do do that without realizing it.
  6. flc120
    flc120 Heavy Load Member
    Jul 11, 2012
    916
    Thanks Received:
    122
    Miami,FL (yeah i know :( )
    wow picky lil buckets arent they lol.
  7. Scorcher21
    Apr 20, 2011
    146
    Thanks Received:
    141
    Crossville Tn
    lol yeah least with this issue. Dont mind the truck though. Bit of a dog on hills but not bad.
  8. Scorcher21
    Apr 20, 2011
    146
    Thanks Received:
    141
    Crossville Tn
    Was thinking about this morning when I hit a dock. It can't be the order of operations, because every time I hit a dock, I always keep a little pressure on the dock while in reverse when I pop the brakes. And it surely doesn't 'get mad'(lol) every time I dock. so it's got to be something else.
  9. heavyhaulerss
    Dec 23, 2009
    3,723
    Thanks Received:
    2,040
    AL/TN BORDER
    horn beeps after shutoff. the truck likes you. does not want you to leave. it's scared to be left alone. read it a bedtime story.:yes2557:
    Rusty970, fireman5523 and Heavyd Thank this.
  10. Scorcher21
    Apr 20, 2011
    146
    Thanks Received:
    141
    Crossville Tn
    LOL, Pretty sure I'd look like a fool soothing my truck reassuring it i'll be right back. However If I dont get a better idea i may try it.:biggrin_25520:
