How are rates for O/O's at the moment?
Discussion in 'Ask An Owner Operator' started by Beaver9, Nov 14, 2022.
  1. Beaver9
    Beaver9 Heavy Load Member
    Jun 15, 2020
    966
    Thanks Received:
    1,183
    I closed the DAT account a few months back. With holidays around the corner I was wondering if rates are starting to go higher.
    Do you think rates will peak in winter during snowstorms as usual that might push brokers to book loads ahead of time for higher rates?
    I'm staying home tomorrow. The same for Wednesday. I might lose one to two days of work every week because I didn't want to go down $100 per load. I don't know if the broker is bluffing the shipper is bidding. For sure, the load tomorrow was already taken by someone else. But the winter is coming and I don't want to haul for less not knowing what the weather will be since those are booked usually one week in advance.
    I don't know why people haul that cheap. And how can they run their equipment to the ground with rates like that. You can only do it for so long until...
    OOIDA can't predict anything. They talked about shortage of drivers all the time. Does anyone even read their news? They can only see an inch in front of them. For me they seem to be useless.
    Lite bug Thanks this.
  2. UItraman
    UItraman Bobtail Member
    Oct 25, 2022
    25
    Thanks Received:
    41
    It's only going to get worse.
    Lite bug, Rickp, Rideandrepair and 2 others Thank this.
  3. Arctic_fox
    Sep 16, 2016
    4,247
    Thanks Received:
    22,368
    Bend over, hold your ankles and hope bubbah uses lube because you aint seen nothing yet.
  4. Kenworth6969
    Jul 3, 2020
    2,819
    Thanks Received:
    8,317
  5. Beaver9
    Jun 15, 2020
    966
    Thanks Received:
    1,183
    Do that
    Rideandrepair Thanks this.
  6. Arctic_fox
    Sep 16, 2016
    4,247
    Thanks Received:
    22,368
    Nahhh i gots my plan B to go work for a mine that has a standing offer for me. Plan C of using my college degree and plan D of finishing my welding certification and becoming an apprentice welder.
  7. Diesel Dave
    Jan 20, 2010
    8,851
    Thanks Received:
    25,970
    Hesperia, Ca.
    Old News. You’ll be surprised how many so NO to cheap freight but still haul as a back haul. It’s been this way since deregulation. You must be new.
  8. Beaver9
    Jun 15, 2020
    966
    Thanks Received:
    1,183
    Good luck then...
    Degree means nothing at times...
    Rideandrepair and Stringb8n Thank this.
  9. Arctic_fox
    Sep 16, 2016
    4,247
    Thanks Received:
    22,368
    Hence it being plan C, but i should be fine. I was more pokeing fun at the rates are falling panic. Im leased to a carrier and even if by mischance they fail i have relitives and contacts in several other divisions of trucking /shrug
  10. Kenworth6969
    Jul 3, 2020
    2,819
    Thanks Received:
    8,317
    A day in the life of trying to pick a load off the board in 2022.
    Sully92, Beaver9, lual and 7 others Thank this.
