how did u mount your amp
Discussion in 'CB Radio Forum' started by Little Jon, Oct 21, 2012.
  1. Little Jon
    Little Jon Bobtail Member
    Jun 10, 2012
    27
    Thanks Received:
    7
    Wildwood, Fl
    Getting ready to install a small linear amp once I get a few small issues under control. Problem is the amp doesnt have any sort of holes to screw it down to anything. Are there any pics out there of how you secured your amp so its not moving around while driving. Looking for ideas/inspiration. Thanx.
  2. dude6710
    dude6710 Road Train Member
    Mar 26, 2010
    2,162
    Thanks Received:
    622
    MN
    I cut small pieces of sheet medal and attached them to the amp and use the existing metal sticking out to attach to the dash side
    Little Jon Thanks this.
  3. Outlaw CB
    Outlaw CB Light Load Member
    May 26, 2012
    260
    Thanks Received:
    179
    Unless the radio is in a hole most use two strips of Velcro and two large zip ties to mount it to the radio, under or over depending upon whether the radio is hanging in a bracket or on the dash. The big ties support the weight and the Velcro keeps it from sliding around. The fins are kept open to the air so in some cases the amp is upside down. Not too bad especially if the front face is symmetrical so that it can be turned over as in the 225 Palomar. Usually a couple wires to switches inside need to be lengthened so it will turn over and bolt back in. This way the fins get the air but the writing on the switches is right side up. Fairly easy work. Normally when I put these together I did not use a 3 foot jumper, I made a custom jumper which just fits making a nice U from radio to amplifier.
  4. Turbo-T
    Turbo-T Road Train Member
    May 31, 2009
    1,953
    Thanks Received:
    708
    What kind of amp?
    Some amps have flanges you can drill holes in if needed, others have a U bracket they set in.
  5. Little Jon
    Jun 10, 2012
    27
    Thanks Received:
    7
    Wildwood, Fl
    midnight special 250/ no flanges or bracket on amp. this is my problem
  6. dude6710
    Mar 26, 2010
    2,162
    Thanks Received:
    622
    MN
    I have the ms 500 just do what I did. If yours has a fan just bend the metal brackets you make from tin to allow clearance
  7. mike5511
    mike5511 Road Train Member
    May 15, 2011
    3,141
    Thanks Received:
    1,523
    NW Arkansas
    velcro....
  8. Turbo-T
    May 31, 2009
    1,953
    Thanks Received:
    708
    Ok....just to give you an idea of what I'm talking about, here's what my amp looks like with the bracket....
    handlebar and Little Jon Thank this.
  9. handlebar
    handlebar Heavy Load Member
    May 28, 2010
    829
    Thanks Received:
    592
    Them Thar Hills, TN, ZIP EIEIO
    Turbo --
    Great bracket; looks really skookum! It looks stout enough that, if there were enough room above it, and the ears were longer, a guy could mount quite a stack of radios in it.
    If I had any sense of being able to work with metal (like even how to bend stock that thick), I like to think that's what I'd have in my van. Nice job.
    73,
    Handlebar
  10. Flip Flops
    Flip Flops Medium Load Member
    Jun 1, 2012
    603
    Thanks Received:
    304
    The Left Lane..
    When I ran one I didn't mount it anywhere....It was a X Force 400HD that sat on the floor behind the drivers seat.
    I ran 4 gauge direct off the batteries up thru a grommet in the floor of the closet of a 379 Pete..
    I also used quick disconnects so I could pull it out when I left the truck at the yard....I bought everything I needed for that setup from Rolling Radios in Richmond, VA..
