how do I alley dock with 5 meters in front of me?
Discussion in 'Questions From New Drivers' started by A Bug, Oct 24, 2014.
  1. A Bug
    A Bug Heavy Load Member
    Mar 15, 2014
    914
    Thanks Received:
    1,850
    Sevierville TN
    Rigjt now i am crooked while backed up to a doc. I have only five meters of space in front of me and about the same to my driver side. Walls on both sides of me up to my cab. I cannot figure how to straighten this thing out.
    I hate these little yatds
  2. CellNet
    CellNet Light Load Member
    Jun 19, 2011
    206
    Thanks Received:
    82
    Chicago IL
    Can you drop the trailer?
    gpsman Thanks this.
  3. gpsman
    gpsman Road Train Member
    Dec 10, 2013
    1,581
    Thanks Received:
    1,211
    45212/59759
    That's "good training". If it was easy, anyone could do it. All your difficult situations can make you a better driver... or not. The thing to remember is, backing is mostly about the setting-up part, not the backing up part..
    Stick with this job for long and you'll find another that's worse.
  4. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    Something is not right with the scenario as you describe it. No way you can be backed up to a dock with a 48-53 foot trailer behind you, walls/trucks on both sides, and with only 5 meters currently available in front of you unless you are on a zero-turn mower.
  5. tirednaz
    tirednaz Heavy Load Member
    Oct 4, 2011
    838
    Thanks Received:
    430
    Arizona
    I am not there to see it, but. In the past I have done this by first pulling up until the rear of my trailer is maybe 8 to10 yards past the opening staying close to the opening. Then slide my trailer tandoms to the rear. Turn my wheels hard right assuming you are set up to the drivers side. start backing into the hole as my trailer clears the opening slide my trailer tandums foward. Then continue backing with the space left. This is a hard jackknife watch your tractor.
  6. AppalachianTrucker
    AppalachianTrucker Heavy Load Member
    May 25, 2014
    708
    Thanks Received:
    552
    Orion Arm
    Backed up, jacked up, wiggle up and down.
    Jack 'em and stack 'em!
    CargoWahgo Thanks this.
  7. RubberDuck198
    RubberDuck198 Light Load Member
    Mar 16, 2014
    216
    Thanks Received:
    150
    Lemme check my atlas
    Apparently you've never been to the post office DC in downtown indy.
  8. moraramis
    moraramis Light Load Member
    Aug 2, 2014
    224
    Thanks Received:
    253
    Federal emission regulations have become so tight now that the industry is welding fifth wheels onto Toyota Prius' and making them haul freight. That is how he was able to back the trailer in like that.
    X-Country, RubberDuck198 and Pmracing Thank this.
  9. fsltrailblazer
    fsltrailblazer Bobtail Member
    Oct 24, 2014
    7
    Thanks Received:
    post a picture
  10. Numb
    Numb Crusty Curmudgeon
    Jan 30, 2012
    4,109
    Thanks Received:
    9,505
    Charlotte, N.Carolina
    meters??
    I use use inches, feet and yards.
    Pedigreed Bulldog Thanks this.
