How do I know how much fuel I am really using?
Discussion in 'Swift' started by fr8monkey, Apr 15, 2013.
  1. fr8monkey
    fr8monkey Road Train Member
    Sep 16, 2009
    2,421
    Thanks Received:
    1,210
    Right behind you
    I keep coming up short on fuel lately?...maybe. my fuel monitor on the truck and the quaullcomm are withing 1/10th of a mpg..but yet guage shows empty(I know its not that accurate always) so i'm coming up 50 gals shorter than I should,or am I? I mean are the trucks monitor and the quallcom going off the same thing?....50 gals short therefore short in my wallet:biggrin_25513:
  2. SLANT6
    SLANT6 Road Train Member
    Dec 3, 2012
    1,094
    Thanks Received:
    1,376
    The Nut House
    50 gallons short?? Is someone stealing your fuel while you are parked? Also I would never trust a dashboard fuel gauge in a heavy truck. I would keep track of miles run and gallons to fill to capacity and keep a running tally every day. Forget the electronic fuel monitor, qualcomm etc. Know your trucks fuel capacity, start with full tanks and figure usage every day.
    fr8monkey Thanks this.
  3. chemsoldier1
    chemsoldier1 Medium Load Member
    Apr 10, 2011
    458
    Thanks Received:
    210
    Lufkin, TX
    The only 100% accurate way to track fuel usage is to log every fuel purchase and divide miles per gallon. I do mine at the end of the month so I get a total for the month. I don't rely on what my elog says as its just an estimate based on computations from the ECM and its own internal processor. If you consistently are getting ridiculous numbers for fuel mileage when you do your own math, you need to think of what could be causing the problem. Is there a mechanical problem with the truck? Is there a fuel leak? Or could somebody be siphoning from your tanks when you park?
  4. MrEd
    MrEd Road Train Member
    Sep 2, 2011
    2,196
    Thanks Received:
    2,836
    Winfred, SD
    Those fuel monitors use some sort of computer program. The qualcom usually goes off what is programmed into it for what the company thinks you should be getting. Neither one, even if they happen to match, are very accurate. You need to manually calculate it yourself each time you top off your tanks. Divide the miles driven since the last top off by the number of gallons you put in. Do that for awhile till you get an idea what your truck really gets for fuel mileage. Its the only way to really know, as fuel gauges are not really too accurate either.
  5. sharp.dressed.man
    sharp.dressed.man Heavy Load Member
    Dec 10, 2011
    701
    Thanks Received:
    507
    IL
    Would one of you care to expand on the mpg calculation method?
    I get what you all are saying, but say you put in 100 gallons and you go 350 miles then you get another assignment and put another 75 gallons in wouldn't your calculation be off because you wouldn't have an accurate measure of how many gallons are left out of the original 100 after the first trip?
  6. SLANT6
    Dec 3, 2012
    1,094
    Thanks Received:
    1,376
    The Nut House
    You start with full tanks. The next time you take on fuel you have to again fill the tanks. If you do not fill to capacity every time you have no way of accurately calculating fuel mileage etc.
    sharp.dressed.man and fr8monkey Thank this.
  7. oneperfectrun
    oneperfectrun Light Load Member
    Dec 18, 2010
    131
    Thanks Received:
    47
    Fulton, MS
    Just keep up with how much you put in each time you fuel without topping off and add it to the gallons the next time you top off. Total your gallons together and use mileage from last top off. This is how I do it between fills.
    MrEd, sharp.dressed.man and fr8monkey Thank this.
  8. sharp.dressed.man
    Dec 10, 2011
    701
    Thanks Received:
    507
    IL
    Ah yes I've got it now. Thanks for the explanation. I appreciate it.
  9. oneperfectrun
    Dec 18, 2010
    131
    Thanks Received:
    47
    Fulton, MS
    Here is a simple iPhone app that I use every time I refuel to calculate and save my mileage. You only type in miles and total gallons and it does the figuring for you. Very simple, no frills, app. The name of it is Mileage Keeper.
    An actual screen shot from my mileage. It shows mileage from each fueling and keeps a total average mileage from all fuel.
  10. fr8monkey
    Sep 16, 2009
    2,421
    Thanks Received:
    1,210
    Right behind you
    Thanks for the app I installed it...I will see how that works....
