How hard is it to change to a lift axle on Dry Van
Discussion in 'Ask An Owner Operator' started by Siinman, Mar 22, 2022.
  1. Siinman
    Siinman Road Train Member
    Mar 5, 2017
    5,289
    Thanks Received:
    13,394
    Kansas City, MO.
    Have a 2022 Utility Dry Van with Hendrickson sliding axle. Wondering how hard and how much it would cost to make it to a lift axle? I have not tried to contact anyone yet as just wondering if anyone has done it before?
  2. rollin coal
    rollin coal Road Train Member
    Mar 29, 2008
    13,289
    Thanks Received:
    26,809
    TN
    It's not hard to do or have have done but depending on what suspension you have I'd advise against it. Because you probably have the most common HKANT 40K suspension under there (most tandem dry vans & reefers have these axles) and Hendrickson does not recommend installing a lift axle on those. I did it to a brand new van back in 2015 and it was a complete waste of money. I got about 3 inches of lift out of it. Tires would scuff badly in the raised position on even the smallest of bumps in the highway at speed so I ended up never raising them up. If you want a lift axle under a dry van the best way is to either buy a used one that is spec'd with a smart lift axle or order one on a brand new one. They get about 5" or maybe even 6" of lift out of the Hendrickson smart lift.
    Siinman and Midwest Trucker Thank this.
  3. Siinman
    Mar 5, 2017
    5,289
    Thanks Received:
    13,394
    Kansas City, MO.
    That is most likely what I will do in the end. Just wondering more than anything. Gonna do a whole new set up in a couple more years.
  4. rollin coal
    Mar 29, 2008
    13,289
    Thanks Received:
    26,809
    TN
    I've seen the ones on smart lift out here scuff before mostly because our interstates are in such terrible shape. Frankly I wouldn't have a lift on any closed tandem trailer. Now spread axle is another thing altogether. I wouldn't have a spread axle without a lift. I saw a nice one on a spread axle reefer the other day ago the driver had the option to lift either the front or the rear axle.
    Siinman Thanks this.
  5. Siinman
    Mar 5, 2017
    5,289
    Thanks Received:
    13,394
    Kansas City, MO.
    Now that would be sweet to have. I almost got a Great Dane with a spread and lift axle before I got this Utility van. Should had went that way but didn't make a lot of sense at the time for what I was doing.
  6. Siinman
    Mar 5, 2017
    5,289
    Thanks Received:
    13,394
    Kansas City, MO.
    I also gonna guess it is the #### bridges. I hate that area because of the rough ride on start and end of almost every bridge.
  7. abyliks
    abyliks Road Train Member
    May 2, 2010
    3,893
    Thanks Received:
    9,104
    ludlow MA
    Good luck, I spent 3 ##### days on the phone 2 weeks ago trying to find a new Hendrickson slide/axle assembly for my trailer, going to a 10’2 with a front lift, ended up doing all the brake/Bering/spiders on my set because I could not find one in the next ~4-6 months and no one would give me a price on one until it actually showed up,
    Siinman and 77fib77 Thank this.
