how in the hell
Discussion in 'Questions From New Drivers' started by Freebird135, Aug 14, 2009.
  1. Freebird135
    Freebird135 Road Train Member
    May 7, 2009
    1,527
    Thanks Received:
    906
    In the air conditioning
    do you downshift a super 10? :biggrin_2554:
  2. brsims
    brsims Road Train Member
    Aug 8, 2009
    5,296
    Thanks Received:
    6,521
    Meadville, PA
    Flip the side splitter to the low range, lift off the fuel, then bring the rpms back up and lift off the fuel again. If I remember it right. If you gotta move the stick, move the side splitter to the high range, and downshift just like a regular ten speed. Again, if I remember it right. Been a few years since I dealt with one.
  3. dirtracer13
    dirtracer13 Light Load Member
    Jul 30, 2009
    65
    Thanks Received:
    5
    WV
    I believe you flip to low side let off gas revit up and once rpms come up it will engage on its own. Then to go down to the next you flip slector to high side and move gear shift as normal. I dont think you have to let off the second time as was explained in previous post.
  4. 4seasons
    4seasons Light Load Member
    Jul 1, 2009
    60
    Thanks Received:
    16
    Greeneville, TN
    I skip half on the way down unless I downshifting to pull a grade. I let the rpms drop to 1200 in 10 pull the switch to low let off then bump to 1600. Then I don't touch the switch again, just let it drop to 1000 then hit a lower hole. The last super 10 I drove was a messed up top 2 model. If you left the switch in high it would pop out on the way down and leave you floating.
  5. TripleSix
    18,492
    Thanks Received:
    129,514
    You downshift a super10 the same way you downshift an 18speed or 13 speed.
    10th.brake. thumb switch back blip (throttle). 9th.brake.thumb switch foward.blip. stick straight foward.8th.brake.thumb switch back.blip.7th.brake thumb switch foward.blip. stick backwards and left 1 notch.6th.brake.thumb switch back.blip.5th.brake.
    thumb switch foward.blip.stick straight foward.4th.brake.thumb switch backwards.blip.3rd.brake.thumb switch foward.blip.stick back and far left as you go.2nd.brake.thumb switch back.blip. 1st gear.
  6. TripleSix
    18,492
    Thanks Received:
    129,514
    Go to youtube.com and look for "Jake Brake of Doom II" for an alternative version.
  7. 25(2)+2
    Sep 18, 2006
    18,750
    Thanks Received:
    45,476
    the road less travelled
    Like he said, A Super 10 is basically just an 18 without a range selector, or the top range of a 13. I always thought it would be better than a straight 10, if the splitter quit and all you had left was the stick, it would be much more drivable than a straight locked in low range or high range, BTDT
    I don't care for the auto-shift thing they came out within the top 2, not much reason for that complication. I was told that was why CRST went from binder to shaker and the straight 10. Too many problems with it not working right.
  8. TripleSix
    18,492
    Thanks Received:
    129,514
    I dont like the Top2 thingie either. I drove a truck with a "9speed top2". It was actually a 10 speed with 9th and 10th shifting automatically. When it works, its decent. When it breaks, or in my case, the company beancounters had the trucks castrated and cut down, you lose your most important highway pulling gear (the one with the 1:1 ratio)
    MAJOR SUCKAGE!
