How many maintenance issues is too much?
Discussion in 'Questions From New Drivers' started by bertita1986, Feb 20, 2018.
  1. bertita1986
    bertita1986 Light Load Member
    Sep 30, 2017
    174
    Thanks Received:
    75
    About every third trailer hooked up to has an issue that requires fixing. Mostly DOT violation issues.
    Maintenance department is handled by a jerk, so I guess no one wants to deal with him, so they just don't report issues.
  2. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    You're going to find this at lot of places, big and small. But some are worse than others. And a smaller fleet of all old[er] trailers is never going to see any relief.
    I know that not an answer to your question but that's all I can offer without knowing more about the fleet you're dealing with or seeing it first hand.
    KB3MMX Thanks this.
  3. gokiddogo
    gokiddogo Road Train Member
    Mar 5, 2012
    8,786
    Thanks Received:
    14,768
    Ontario Canada
    Sounds like a great place to work. Not.
    If it doesn't pass your dot inspection then don't haul it down the road. It's your ssa when the dot man discovers the defects, whether it's before or after the accident. There's plenty of places that don't put up with junk equipment. The same places usually don't put up with b.s. in general whether it be from drivers, shippers/receivers, anybody. If something is worth doing then it's worth doing right. Forget all this corner cutting b.s.
  4. ChaoSS
    ChaoSS Road Train Member
    Sep 20, 2014
    3,338
    Thanks Received:
    6,757
    I haven't picked up a trailer in months that hasn't needed something to be fixed on it.
    I won't take another job where I don't have a dedicated trailer unless I'm making hourly.
    Toomanybikes Thanks this.
  5. pmdriver
    pmdriver Road Train Member
    Nov 14, 2017
    2,338
    Thanks Received:
    3,503
    1 issue is plenty for the DOT folks, if you are finding them on dropped trailers that means some drivers are not doing a post trip inspection, so pay a visit to the safety dept. and be the snitch. If it is a yard used by more than 1 company sometimes the others will select parts needed to make their own trailer compliant so you have a whole nest to blame it on.
    KB3MMX Thanks this.
  6. Antinomian
    Antinomian Road Train Member
    Feb 17, 2013
    2,106
    Thanks Received:
    3,321
    Most companies don't pay or pay very little for the time it takes to haul a trailer back to their yard and get it fixed. So drivers will just drop it at their next stop and leave the issue for the next guy. When you work for a large carrier and have to do a drop and hook you learn to go down the line of empties and pick the best one. When I drove for Swift I used to laugh at the ancient looking Swift trailers sitting around at Walmart DC's. Some of them looked like they had been sitting there for years.
    KB3MMX, Mike2633 and Toomanybikes Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,135
    White County, Arkansas
    Head into a trailer shop on the road, a independant or chain etc. Generate a workorder. Warn the office people about a pending bill for necessary repairs that need signing off on the PTI for that trailer after the work is finished.
    Mr Grouch in the shop will be so lonely...
    KB3MMX and Brickwall Thank this.
  8. Toomanybikes
    Toomanybikes Road Train Member
    Apr 8, 2009
    2,360
    Thanks Received:
    3,120
    ONE in THREE is great odds. My guess if you looked a little harder you could find problems with the other two also.
    These trucking companies reel drivers in with the myth that they have like 90% drop and hook. People will sign up with their CPM program with the idea that all your time will be spent running miles and making money. Not only is the drop and hook statistic a complete myth, they know their trailers are complete junk, beat to crap by their steering wheel holders and they could care less because they don't pay the tickets. You do driver. Your time is free in trying to get these trailers repaired and acceptable to the shipper.
    How much you want to bet less then half of the 1/3 of trailers you find problems with are written up in the post-trip. How much do they pay a driver for doing the post-trip in your company? Well there is your answer.
    KB3MMX, x1Heavy and Mike2633 Thank this.
  9. bertita1986
    Sep 30, 2017
    174
    Thanks Received:
    75
    Okay any recommendations?
    x1Heavy Thanks this.
  10. gokiddogo
    Mar 5, 2012
    8,786
    Thanks Received:
    14,768
    Ontario Canada
    @Chinatown
    Is the resident expert on trucking companies around this joint
