How much does it cost to fix an oil leak in the freeze plug of a 1997 Peterbilt
Discussion in 'Peterbilt Forum' started by Cin Dehoyos, Aug 13, 2015.
  1. Cin Dehoyos
    Cin Dehoyos Bobtail Member
    Aug 13, 2015
    Thanks Received:
    How much does it cost to e
    Repair an oil leak from a freeze plug on a 1997 Peterbilt
  2. damutt
    damutt Road Train Member
    May 6, 2013
    1,126
    Thanks Received:
    370
    cat? Cummins?Detroit?,
    why would you be leaking oil from a freeze plug???? IIRC the freeze plugs are for the cooling system(antifreeze)
  3. AModelCat
    29,225
    Thanks Received:
    159,412
    A frost plug for the cooling system shouldn't be that expensive. You can even buy a frost plug kit pretty cheap and do it yourself. They aren't that hard to change.
  4. damutt
    May 6, 2013
    1,126
    Thanks Received:
    370
    if it is a freeze plug, most expesnive part would be fresh coolant, but that needs to be done every so often anyway
  5. bubbanbrenda
    bubbanbrenda Road Train Member
    Feb 27, 2011
    1,388
    Thanks Received:
    650
    Middletown,Oh.
    If you have oil coming out of a freeze plug you have bigger problems than an oil leak.
    mc8541ss Thanks this.
