How much force is in a tire blowout? A lot!!!
Discussion in 'Trucking Accidents' started by MrBoDarville, Dec 17, 2019.
  1. MrBoDarville
    MrBoDarville Light Load Member
    Feb 13, 2019
    66
    Thanks Received:
    190
    PE_T, skellr, Lepton1 and 3 others Thank this.
  2. bryan21384
    bryan21384 Road Train Member
    Sep 18, 2009
    14,847
    Thanks Received:
    32,113
    Memphis, TN
    Hell everybody better know it!!!! Hiw much damage always occurs after a blow out? New mudflap, if a steer blows out, the whole front end, you know.....
    Lepton1, FerrissWheel and mjd4277 Thank this.
  3. AModelCat
    29,146
    Thanks Received:
    158,391
    Father of one of my friends had a truck tire blow up next to him. Caused a lot of damage to him.
    PE_T, Lepton1 and FerrissWheel Thank this.
  4. INRUT
    INRUT Medium Load Member
    Aug 21, 2016
    530
    Thanks Received:
    1,892
    I had one blow right after I parked at a casino in AZ one evening, thought a bomb went off it was so loud. I can absolutely see one killing someone
  5. Mid-May Trucker
    Mid-May Trucker Road Train Member
    Oct 23, 2018
    1,118
    Thanks Received:
    2,079
    Happens all the time in India.
    FerrissWheel Thanks this.
  6. mjd4277
    mjd4277 Road Train Member
    Oct 4, 2015
    14,132
    Thanks Received:
    42,882
    Fitchburg,MA
    I had a drive tire blow on me driving in North Carolina. When it blew it sounded like either a shotgun blast or someone banging on a metal trash can!
  7. stayinback
    stayinback Road Train Member
    Jan 24, 2014
    3,911
    Thanks Received:
    8,256
    chicago,il
    thats why 95% of drivers dont even check air pressures--Thump em n go- Plop that butt in the drivers chair with lumbar and go make your dispatch some money.
    I have my compressor set at 122psi of air to tool- I put in the chuck and leave the room until the "Honk Honk " bicycle horn is heard-
    D.Tibbitt and FerrissWheel Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,135
    White County, Arkansas
    I have seen truck tires take people out and leave them shattered and in bad need of life flight. There is a world class trauma center in Baltimore that has saved a few of them so far.
    The only mechanics who come out of this in a ok shape are those who use special cages to inflate truck tires before putting them on. In my time we would stick a hose into the input and have a smoke listening for the shop compressor to essentially quit. Then take a pressure reading.
    Liveleak.com - Mechanic found a quicker way to remove two tires off a truck
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    Jul 11, 2012
    3,370
    Thanks Received:
    7,769
    in the bush somewhere
    Back in the days of split rims, my grandfather would chain the tire to a tree, hook the air hose to it, and walk away.
    FerrissWheel and x1Heavy Thank this.
  10. 25(2)+2
    Sep 18, 2006
    18,750
    Thanks Received:
    45,476
    the road less travelled
    Even a new tire can blow while inflating, best to listen for anything odd, and if you hear something akin to corn popping, run, don't walk, away. Even in a cage, the air pressure blast is deafening and can blow you off your feet and cause impact injuries. Maybe like that dummie.
