I could use some help please.
Discussion in 'Questions From New Drivers' started by TruckingSexy, Nov 15, 2017.
  1. TruckingSexy
    TruckingSexy Light Load Member
    Nov 2, 2017
    73
    Thanks Received:
    29
    I have an automatic freightliner cascadia. It keeps saying creep mode aborted while moving in low gears. And it does it when moving in reverse too and it is causing so real trouble while backing up. Making it extremely difficult to just back up with out giving it too much power. I have not had this issue with this truck till now. What is causing it to go into creep mode and why is it aborting? What exactly is creep mode?
  2. JLMooreKCMO
    JLMooreKCMO Light Load Member
    Jun 8, 2007
    282
    Thanks Received:
    295
    Clutch is probably overheating. At least that is what mine says. The D12 transmission is in my opinion a P.O.S. that is why I'm switching to a truck with a stick.
  3. Steel Dragon
    Steel Dragon Road Train Member
    Nov 23, 2015
    2,681
    Thanks Received:
    2,833
    Don't touch the brakes if you want to try using creep mode,as it will abort the operation.
    Just takes some practice and very light throttle control.
  4. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,135
    White County, Arkansas
    The Reverse in the automatic transmission should be in the lowest possible gear, once you start reversing, your clutch is all the way out, you do not ride it while following your trailer around into the dock or wherever. Should you need to stop and pull up, engage the clutch.
    Clutch increase in temperature two ways, slipping out of adjustment or you standing halfway on the clutch while the tractor noses down and wants to buck you as you jiggle the fuel...
    You may or may not be doing that I don't know.
    Disclaimer your specific auto may be different. But my thinking remains the same.
  5. TruckingSexy
    Nov 2, 2017
    73
    Thanks Received:
    29
    Thing is that it won't move back unless it's gases. Now this particular load is very heavy but I still can't stand it. It has to have so much power to move it just lunges back.
    x1Heavy Thanks this.
  6. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    Creep mode should be enabled by default at very low speeds. It is typically disabled inadvertently by the driver.
    Also check that it's not disabled in the user parameters setting. If it seems to otherwise not be working properly, you might try updating the software (take to your shop or a dealer)
  7. NightWind
    NightWind Road Train Member
    Nov 11, 2006
    2,685
    Thanks Received:
    18,927
    Sunny South, AL
    Votes you getting a truck with a manual transmission
    Rugerfan Thanks this.
  8. STexan
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    What year freightliner are we talking about? The 2018's behave a bit differently than prior years.
  9. Coover
    Coover Road Train Member
    Dec 9, 2016
    1,573
    Thanks Received:
    3,593
    On a auto DD 12 transmission creep mode is a way for truck to accelerate slowly 2-3 mph when taking foot off of brake without touching accelerator pedal. Supposedly used to "creep" up in bumper to bumper traffic and such. Any use of brake pedal repeatedly or mashing accelerator will cancel creep mode.
    There is also the urban dictionary definition
    Urban Dictionary: Creep Mode
    AModelCat, x1Heavy and SHOJim Thank this.
  10. Rugerfan
    Rugerfan Road Train Member
    May 3, 2011
    7,338
    Thanks Received:
    36,207
    Redding,CA
    I’d take it back to the yard and get in a manual
    shogun and Toomanybikes Thank this.
