I need some advice... recent CDL grad
Discussion in 'Questions From New Drivers' started by vscore24, May 28, 2013.
  1. vscore24
    vscore24 Bobtail Member
    Feb 27, 2013
    4
    Thanks Received:
    OK, so here's my problem...
    I've been out of work for a while so I decided to get my CDL to try and get back on my feet. I have a degree but the job market is absolutely dismal where I live (as I am sure it is in many places). The commercial truck driving school I went to provided me with about 18 hours of actual road time over 5 weeks (they recorded it as 20) and I failed the state test twice on the backing portion- I can straight back alright but my angle backing plain sucks. I passed the state test on the third try by jack-knifing and pulling forward, a technique that probably isn't the best for obvious reasons. I think I can correct it but I am lacking the knowledge to do so on my own and while different people have told me different things it just really hasn't clicked yet- I'm starting to get the part where the cab pushes the trailer but I'm having a hard time judging my corrections while at an angle. My shifting could be better but the feedback I received is it could also be worse. I've tried to gain employment with two companies that have a solid reputation (Schneider and Roehl) and got rejected by both after about 5 days of orientation. I left on good terms but both companies felt I needed a lot of work on basic skills- more than they were willing to provide in the alloted time. Feedback I received included mirror usage (clipped two curbs in an urban area- we made about 20 turns), driving too slow (I'm a bit nervous still around cities), downshifting needs work and I need to learn how to couple (considering it was the first time I did it, I felt I did OK). I thought about trying Swift since they have a longer program but in reality after talking to some drivers and reading a lot of negative reviews there seems to be a lot of 'red flags' concerning them which makes me think such a move would be unwise- last thing I need to do is get a crappy trainer or be put in an unsafe situation where I back into something or someone gets hurt. Without getting into specifics- People with a temper don't help things either, the more relaxed trainers I've worked with so far I've learned the most from and the louder, more aggressive ones tend to cause me to freeze up and screw up- I still need work on skills and I don't have the money to put toward more schooling (I would say I have about 25 hours of actual driving under my belt now).
    The question is this something you want to do keeps popping up and with the little experience I have I really can't answer it. I could see where driving a truck is a decent living and a lot more liberating than an office- but I also see where it is a lot more dangerous and while fear can be a good thing, I think fear is part of my problem- and a lot of that at this point has to do with the size of the vehicle, backing and cornering and the creeping realization of just how much time OTR drivers are on the road (I think I can do this for a year). I realize this job isn't for everybody, but I think if I had a company willing to work with me a bit I might do OK (Schneider seemed to think so). I just don't know where to go or what to do so I'm looking to the internet for an answer. No one I know that well drives a truck for a living so they really don't understand the risk- it's not a simple job where if you screw up all is still well. My options at this point are to find a company that will train me decently or give up... the later option isn't desirable but I don't want to risk hurting someone either. Any advice or helpful criticism is appreciated. Thanks.
    Chinatown Thanks this.
  2. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    75,033
    Thanks Received:
    171,100
    Henderson, NV & Orient
    First of all, tell us where you live; this pertains to hiring areas.
    Don't give up though, you will succeed. Take what you can get for now, then move on in 6 mos.
    In the meantime, study for the endorsements & consider a passport & TWIC which will give more opportunities after you get more training.
  3. Chinatown
    Aug 28, 2011
    75,033
    Thanks Received:
    171,100
    Check Panther Expedite. They hire for cargo vans & straight trucks, drivers with CDL & no experience.
  4. Crossroads
    Crossroads Light Load Member
    Feb 28, 2013
    239
    Thanks Received:
    236
    Lumberton NC
    JUst learn to relax a little. You might go to a local tractor trailer school, or return to the one you graduated from and work specifically in backing for a whole day, and maybe any other areas you feel you need work.
  5. bubbavirus
    bubbavirus Medium Load Member
    Oct 6, 2006
    348
    Thanks Received:
    59
    directly over the center of the Earth.
    In orientation test drive I downshifted instead of upshifting, testing guy (wanna be Kenny Chesney) called me on it, think I got a day or two more testing for that...
    On the road, I learned, if it was EZ anyone would do it...
  6. vscore24
    Feb 27, 2013
    4
    Thanks Received:
    Thanks China, I just got my new passport and am waiting on my HAZMAT approval (its been about four weeks). I know a TWIC card would help but I'm low on funds right now- really low. I'm in the Chicago area so there are a decent number of opportunities (especially in Gary which is somewhat close)- its more or less making the right move at this point.
  7. MoGooder
    MoGooder Light Load Member
    Mar 15, 2013
    160
    Thanks Received:
    57
    Kenosha, WI
    If you went to a reputable school they should provide a little extra training at no charge. It isn't easy to get comfortable driving when someone is agitated with your mistakes. When I graduated from school I had 20 hours behind the wheel. I couldn't back up and could barely shift. You just need a little more practice then you should qualify for a company to train you. Best wishes in life's journey.
  8. TruckerPete1990
    TruckerPete1990 Road Train Member
    Jul 16, 2012
    8,623
    Thanks Received:
    5,377
    Bentonville Arkansas
    Only 18 hours. The road?? You wasted your money on a fly by night school.. some companies might make u redo training
  9. Barefoot Bree
    Barefoot Bree Bobtail Member
    May 27, 2013
    17
    Thanks Received:
    Everybody loves to put down the entry-level trucking companies, the ones who do their own training, but I think they're great for what they do: take newbie drivers, put them on the road with a trainer, and give them the experience they need to become good drivers and go on to better companies after a year or so. Yeah, it's luck of the draw when it comes to your trainer, but you can usually request a new one if you REALLY don't get along. My suggestion is that you look into one of them: CR England, Prime, etc.
  10. hmtruk
    hmtruk Light Load Member
    Jun 7, 2009
    123
    Thanks Received:
    49
    big lake ,mn
    look for one of the big co that have a training program and go through them. explain what training you have and were you are week in training when talking to them. find one that will work with you to start.swift creat es express roehl prime us truck they are all about the same. find the one that fits your needs and one that you fit there needs. will make for a better out come in the end.
