identify & service tips for air dryer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ezrider_48501, Oct 15, 2013.
  1. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,134
    bismarck, nd
    winter is approaching and i am getting some water in my wet tank so i know my air dryer needs to be serviced soon. however i am not familiar with the air dryer on this truck, never had a truck with this style on it so i was going to have a shop do it while i was in for a oil change and the guy that was there at the time was not familiar with my air dryer aether. so i figure i might as well get fimilar with my air dryer and service it myself. im not sure if this air dryer is orrigional to the truck or if its one someone put on at some other time ect. so i need to find out what kind of air dryer i have
    im guessing you unbolt the end and slide it out and it will have a filter on the inside like the some of the old benex dryers
  2. bubbanbrenda
    bubbanbrenda Road Train Member
    Feb 27, 2011
    1,388
    Thanks Received:
    650
    Middletown,Oh.
    Cetane+ and Ezrider_48501 Thank this.
  3. Semi Crazy
    Semi Crazy Road Train Member
    May 13, 2011
    3,033
    Thanks Received:
    2,047
    Middle Tennessee
    Is that held to that bracket with bungees? Doesn't look like OEM install.
    A Bendix AD-9 comes with all the mounting brackets. All you do is plumb the in/out/signal lines and run a wire for the heater.
    Ezrider_48501 Thanks this.
  4. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,134
    bismarck, nd
    at was originally bolted with brackets to the underside of the bracket its sitting n now. after almost ripping it off i flipped it to the top side but the straps around it that bolt to the bracket are a little fubar after dragging the air dryer so the bungees are just to keep it from vibrating inside the brackets for now till i do something different with it.
  5. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,134
    bismarck, nd
    i was thinking a bit along that line too. just slapping a complete new setup on there but seems like kinda a waste if all this one needs is a new filter. i guess it depends on what it takes to service this darn thing
    and funny you say about exausting the air becouse it actually says that on the cover almost word for word...lol
  6. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,134
    bismarck, nd
  7. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,826
    Thanks Received:
    6,276
    In about 20 years I have never seen a dryer like that! Weird! It seems to be pricey compared to an AD-9. Haldex does make some good stuff. But, I don't like dealing with odd-ball stuff. If that model is popular where you live and work and people have the parts readily available, then go with that. If it were me, I would install an AD-9. They are tried and true. Everyone, everywhere has parts! AD-9 aren't that expensive either.
  8. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,134
    bismarck, nd
    that's kinda my thoughts as well at this point. after i i figured out what i had for a air dryer i found service kits for it and the service kit is $80 and i still have a oddball that no one knows anything about, im thinking i might be better off just putting a ad-9 on
  9. Cetane+
    Cetane+ Road Train Member
    Sep 29, 2013
    1,304
    Thanks Received:
    882
    Albany, NY
    The air dryer does not have any oil in it, wheres the oil coming from? When is the last time the compressor was changed?
  10. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    this one is very simple, easy to change cartrige, requires no purge tank.
