Inconsistent miles
Discussion in 'Questions From New Drivers' started by BIGLEFTYINTX, Mar 24, 2019.
  1. BIGLEFTYINTX
    BIGLEFTYINTX Light Load Member
    Nov 20, 2017
    263
    Thanks Received:
    209
    Wondering if I should be worried about getting inconsistent weekly miles .
    This week 1637
    Last week 2656
    2 weeks ago 2071
    3 weeks ago 1636
    4 weeks ago 2624
    5 weeks ago 1512
    I'm not liking this at all. I didn't sign up for ####ty weeks .
    Sorry for rant
  2. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    That's not too bad.
    What you need to do is take a percentage off your gross earnings and put it into a suitcase calling it savings. So when you have a great week or a great month as you been having here, anytime you don't have good weeks at say 900 miles you will have money to fall back on and do well anyway financially.
    Many truckers hang themselves when they borrow money they have not yet gotten in payroll or live a life with too much debt. They never last very long in trucking.
    Considering the winter we are still enduring this year those are pretty good miles for solo.
    QuietStorm and TravR1 Thank this.
  3. brian991219
    brian991219 Road Train Member
    Aug 10, 2013
    2,955
    Thanks Received:
    5,955
    Lords Valley, PA
    Did you go home on the weeks with lower miles? It typically takes a few hundred to a thousand miles off your week when the carrier tries to schedule a driver for home time.
    Also, nothing is consistent in trucking unless you are on a dedicated route for a dedicated customer. Otherwise this is a hit and miss business, so you run when you can, live like you always will only have 1,600 mile weeks and put the rest away for rainy days.
  4. QuietStorm
    QuietStorm Heavy Load Member
    Dec 11, 2016
    899
    Thanks Received:
    1,416
    Under 2k miles a week more than once in a while is pitiful if you're paid by the mile. That is less than 4 days of driving up and down the 99 in California. Even if you're getting $0.50 a mile I would baulk at that and seriously consider changing companies.
    Personally, If my paycheck is less than $1000 after taxes more than once a month I start to get pissed off. But I also remember when I first started, getting over $500 a week was a good week, haha.
    It all depends on what you're doing and how long you have been doing it.
    x1Heavy, Omega1, PE_T and 2 others Thank this.
  5. PE_T
    PE_T Road Train Member
    Jul 12, 2017
    3,412
    Thanks Received:
    3,788
    Texas (trucking since 02/2013)
    Miles will always be inconsistent for OTR drivers. I would say you want over 2,400 miles on average. So 2k, 2.4k, and 2.8k will average 2.4k. As you gain more experience you will get closer and closer to 3k. There are so many tricks in OTR that can help you boost your weekly miles. Experience and speaking to senior drivers from your company can help.
    QuietStorm Thanks this.
  6. BIGLEFTYINTX
    Nov 20, 2017
    263
    Thanks Received:
    209
    I'm paid .45 a mile. I'm a Texas dedicated route driver , I deliver for pilgrims chicken . I'm either running transfers ,from plant to plant or delivery to customers . Heb, Walmart, kroger and others
    I just started Dec 12 and on my 7 week on my own after training
    PE_T Thanks this.
  7. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    Mar 22, 2018
    743
    Thanks Received:
    1,570
    Yeah the trick is show up as soon as u can forget about apoinment. Hope they loaf or unload u early. Move on to next load.
    88228822 and PE_T Thank this.
  8. kemosabi49
    Jan 13, 2013
    10,670
    Thanks Received:
    45,786
    SW Arkansas
    I would be planning my exit from that company. Probably won't get much better. If your record is clean you can do better.
    Omega1, QuietStorm and x1Heavy Thank this.
  9. PE_T
    Jul 12, 2017
    3,412
    Thanks Received:
    3,788
    I would call them first to see if early pick or delivery is possible. Otherwise, you start your 14 hr clock. Most Walmarts will penalize/charge carriers for early deliveries. Drop and hooks at Walmarts should only be made on the same day.
    88 Alpha Thanks this.
  10. gokiddogo
    gokiddogo Road Train Member
    Mar 5, 2012
    8,786
    Thanks Received:
    14,768
    Ontario Canada
    Sounds like inefficient dispatching..
    I would be upset as the equipment owner if utilisation was that poor, unless doing many short runs...
    TripleSix and x1Heavy Thank this.
