Info on Ultrashift Trannys
Discussion in 'Freightliner Forum' started by supertruckerporkchop, May 4, 2011.
  1. supertruckerporkchop
    supertruckerporkchop Light Load Member
    May 3, 2011
    145
    Thanks Received:
    56
    Galveston, Texas
    Looking to purchase a 2005 Century w/ Detroit 60 and Ultrashift. I'm unsure of gears and rears.
    Trying to get a rough Idea of fuel mileage. I've read anywhere from 4.8 - 7.5. I'm hoping for 6, but idealy would like 6.5. Will be running mostly SouthEast, Midwest, and South regions.
    The trucks have between 410k and 460k and they are trade ins from Us Express.
    Are the autos worth the extra costs? Does Us. Express take care of their trucks??
    Thanks,
    Chop
  2. scatruck
    scatruck Light Load Member
    May 23, 2007
    89
    Thanks Received:
    37
    Bonham TX
    Good question, anyone have any idea?
  3. Socalchuckster
    Socalchuckster Light Load Member
    Sep 10, 2010
    144
    Thanks Received:
    39
    Fontana, CA
    my company truck is a 2007 century with a detroit 60 and the Ultrashift. I mainly run western 11 regional and see a lot of mountains so i have never really had a "steady" mpg to gauge off of. Per the dash i have an average 5.5 mpg. I believe the pitfall of the utrashift is the fact that there is no clutch, which is awesome for downtown stop and go traffic or going up a long mountain (just set the cruise and downshift by hand) but its bad for this reason. The automatic clutch is similar to that of a go-cart, if you're at a stop and want to get moving, you have to step on the throttle until the rpm's get to approx. 950 before the clutch "grabs" and you can start moving. If you have a heavy load it can be quite jarring until you get the hang of it and how to feather the throttle like you would a clutch pedal. Also backing is a whole new experience lol. I think a lot of mpg is wasted in getting going as you cant just slip the clutch with out using throttle to get the truck to start rolling.
    Just my .02
  4. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    Ultrashift is made on Autishift base, but with "automatic" clutch. So it runs like autoshift, but you start w/o clutch pedal
  5. flood
    flood Road Train Member
    Dec 25, 2010
    4,161
    Thanks Received:
    4,031
    we had an 05 just likt the one youare looking at. loved it
    we did have a detroit mechanic change the programing (with us xpress's ok) and the milage went from 6.4 to 7.2 and the truck would pull the hill 8-12 mph faster.
    you need to call us xpress and ask for brakedown (with the vin # in hand)
    1st find out when they got red of the truck..?
    the reason is that for part of 2010 and 2011 they were doing 50,000 oil changes...!!
    2nd if you talk to the right person they call tell you the breakdown history.
    over all they take good care of the trucks as long as the drivers do the same.
    the only thing i will add is that the milage is way off for a old 2005 us xpress, i know that they were keeping most of then and would not trade them out until the had over 600,000 on them
    i just bought an old 06 us xpress volvo. and am happy with it
  6. mgdehn
    mgdehn Bobtail Member
    Sep 20, 2011
    7
    Thanks Received:
    I have a freedomline in a 387 Pete. I get approx 5.25 where ever I run.
  7. Tazz
    Tazz Road Train Member
    Oct 25, 2009
    2,821
    Thanks Received:
    1,133
    Lynchburg,Tn
    Brake check is wheel chocks or a curb. You can check each individually but that eats up a lot of time.
    Chop most of the those will probably do mid 6's easily if driven properly depending on loads you may be up around 7. The loose nut behind the wheel can do more about MPG than transmission's can. They are the exact same ten speed sans a stick.The biggest thing with the autoshifts is adjusting your take offs and backing. You will learn throttle control or suffer whiplash injuries.
