INFRAME QUESTIONS HELP!
Discussion in 'Ask An Owner Operator' started by Dok2304, Jul 26, 2024.
  1. Dok2304
    Dok2304 Light Load Member
    185
    49
    Sep 19, 2013
    Hello everybody, I’m looking for some advice about doing an inframe on a Detroit 60 12.7, from anybody that did this. Anything will help, like what kits they used, OEM, Aftermarket, maybe some repair shops that do this.
    ‘I’ve read that the head and the liner height is the biggest problem with these engines, when do a inframe.
  3. Big Road Skateboard
    7,162
    40,580
    May 2, 2021
    Biggest is likely who will be doing the work
    Feedman, Oxbow, pavrom and 6 others Thank this.
  4. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    I would go genuine OEM, but that’s me. Like BRS mentioned, it’s “who’s” going to do the job that counts. I myself would look for someone that only does green/black motors.
  5. Banker
    Banker Road Train Member
    4,533
    14,756
    Aug 19, 2012
    I used all OEM Detroit parts when I in-framed mine, but my shop is an Authorized Detroit shop so I doubt they would use aftermarket parts if I wanted to. I don’t know enough about aftermarket rebuild kits to have an opinion. I have used Clarke Power Services to do any work inside my motor the last 9 years and have been satisfied with their work. If you can find an old school mechanic at an independent shop who specializes in series 60’s, that would be the next best bet to an Authorized Detroit shop, if he does quality work and stands behind his work if there is a problem. What part of the country do you live in? Someone may know of a shop near you.
  6. 50WT
    50WT Road Train Member
    3,028
    27,827
    Dec 26, 2015
    Liner protrusion is very important, may need to have block cut. Any good shop will know this . Have them check or replace the bull gear .
    As has been said finding a good shop makes all the difference.
    Oxbow and W923 Thank this.
  7. AModelCat
    164,923
    The person doing the work is often the difference between a good rebuild and a terrible one.
    Find a mechanic with OCD. They might take a bit longer but the job will be done right.
  8. Dok2304
    185
    49
    Sep 19, 2013
    Michigan, but I’m willing to travel, as long is not California , hehehe
  9. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    I did one 2 years ago. Hindsight says I should've just bought a reman from Detroit and that is with a good mechanic shop.
    shanman and Oxbow Thank this.
  10. Dok2304
    185
    49
    Sep 19, 2013
    But a new engine it’s like 30K or so, and that’s a rebuilt one not brand new, then you have to pay for removal and install the new one . If the truck was a classic or a Coronado….maybe, but for a Columbia puff, it gets the work done, but I’m not turning my head when I see one.
    After 2 years.. what went wrong, I mean, I see some people are doing ok, some they go another 500k miles after inframe
    Big Road Skateboard Thanks this.
  11. Banker
    4,533
    14,756
    Aug 19, 2012
    I have never used the Clarke in Ft. Wayne, but for years they re-built the motors and assembled new gliders for several large fleets.
