Installing GPS Tracker | 2005 VOLVO 670 | Need help.
Discussion in 'Volvo Forum' started by beno95, Nov 21, 2014.
  1. beno95
    beno95 Bobtail Member
    Feb 15, 2014
    19
    Thanks Received:
    6
    Saint Louis, MO
    We are trying to install a AiriQ gps tracker on a 2005 VOLVO 670 but cant seem to figure out where would be the best place to place it. We need it connected to 12V/24 constant power source, a ground, and a 12V/24 ignition power source. What are your recommendations? And has anyone installed this exact tracker before?
    Thanks in advance!
  2. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    I would suggest u place it behind instrument panel although never installed that type of tracker before or u can even put it behind cigarette lighter in front and get everything from the fuse box which would be easiest way
  3. ChromeNut
    ChromeNut Light Load Member
    May 22, 2014
    70
    Thanks Received:
    39
    Lockport, IL
    I've seen them installed inside the fuse box
  4. beno95
    Feb 15, 2014
    19
    Thanks Received:
    6
    Saint Louis, MO
    What do they mean by ignition power source?
  5. nasriza
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    They mean ignition power when u turn the key to drive position you have batt power all time accessory power only in one position then u have have ignition power with key in drive position it's how gps knows truxk is running
  6. beno95
    Feb 15, 2014
    19
    Thanks Received:
    6
    Saint Louis, MO
    Where would you recommend the best spot for connecting it to the ignition would be?
  7. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    we used to install it under fuse panel. There are ignition and constant power outlets for Body builders, unused and unused small fuse panel. Easy to fit a seal on tracker fuses to avoid driver's cheating
  8. beno95
    Feb 15, 2014
    19
    Thanks Received:
    6
    Saint Louis, MO
    Appreciate it . Thank you.
