Is Drop and Hook
Discussion in 'Questions From New Drivers' started by thelastamericanhippy, Aug 13, 2010.
  1. thelastamericanhippy
    thelastamericanhippy Road Train Member
    Jul 10, 2010
    1,038
    Thanks Received:
    311
    jacksonville, fl
    Always the better deal,
    versus always having the same trailer ??
    Thanks............
  2. blackw900
    blackw900 The Grandfather of Flatbed
    Jul 12, 2009
    5,817
    Thanks Received:
    7,678
    A.W.O.L
    Not in my opinion!
    When you pick up a trailer on a yard somewhere...You inherit all the problems that the previous drivers left it with.
  3. REDD
    REDD The Legend
    Jun 29, 2009
    6,237
    Thanks Received:
    4,291
    Dueling Banjoville
    Exactly.....
    And when you stay hooked to the same trailer.... You know exactly what you've got. What has been fixed, & when. what needs to be fixed, & now!
  4. johnday
    johnday Road Train Member
    Aug 14, 2006
    2,487
    Thanks Received:
    825
    Barton City Mi, under a rock or log
    ,,,, and a lot of times with drop and hook, you can't see how it's loaded.:biggrin_25525:
  5. cpape
    cpape Desk Jockey
    Jul 15, 2010
    2,151
    Thanks Received:
    2,263
    Dubuque, IA
    That is a question with lots of answers. If you are able to drop the trailer at the receiver instead of live unloading, it would seem to be. A lot depends on the trailer you are picking up. If it has a flat tire, you just lost anything you should have gained.
  6. truckerdave1970
    truckerdave1970 On Probation
    Dec 15, 2008
    2,987
    Thanks Received:
    3,289
    Rochester, NY
    But if you happen to hold on to the same trailer for a long time, don't forget to drop it once in awhile and grease your 5th wheel. While you have it disconnected, make sure you take a good look at the 5th wheel and the mounting bolts, basically all the stuff that you can only see when you drop the trailer. You don't want to find out the hard way that something is broken or malfunctioning!
  7. Kittyfoot
    Kittyfoot Crusty Ancient
    Sep 21, 2009
    2,092
    Thanks Received:
    3,056
    Sorrento, Louisiana
    Depends..... drop and hook means you never touch the freight; a quicker turnaround without the delays of loading/unloading. However, the drawback is the trailer you pick up may have issues with lights, brakes, body damage, etc that whoever dropped it didn't take care of. Plus you don't really know anything about whatever's on it (how it's loaded, weight, etc, etc) other than what the BOL says.
    You pays your money and you takes your chances.
  8. blackw900
    Jul 12, 2009
    5,817
    Thanks Received:
    7,678
    A.W.O.L
    Ahhhhhhh......The benefits of flatbedding!
  9. Coonass
    Coonass "Freshy Fresh"
    Sep 23, 2008
    1,080
    Thanks Received:
    1,179
    Exactly what I was thinking.
    The only trailers I drop an hook are MY flat, step, and stretch trailers..:biggrin_25522:
  10. blackw900
    Jul 12, 2009
    5,817
    Thanks Received:
    7,678
    A.W.O.L
    I drop my flat...Grease my fifth wheel...Service my tractor...Hook back up to my flatbed!
    You know....Drop and Hook!:biggrin_25522:
    truckerdave1970 and johnday Thank this.
