is there such a thing as a digital pressure gauge?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by snowwy, Aug 18, 2012.
  1. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,537
    Thanks Received:
    13,274
    i got caught off gaurd last week with a heavy load. gauges looked good. so i'd like to see aobut a digital read out that i can maybe add the weight so i know what i have exactly instead of having to drive 200 miles to the closest truckstop with a scale to find out i'm heavy.
  2. GAlanFink
    GAlanFink Medium Load Member
    May 8, 2012
    334
    Thanks Received:
    271
    Bucks County, PA
    Ever have your Blood Pressure taken?... the simple answer is Yes.
    Is that all you wanted to know?
  3. snowwy
    Jul 6, 2009
    20,537
    Thanks Received:
    13,274
    how about some infor on where to find such a thing would be nice.
  4. Rugerfan
    Rugerfan Road Train Member
    May 3, 2011
    7,327
    Thanks Received:
    36,155
    Redding,CA
    cant you get a scale on your trailer? or a portable ?
  5. GAlanFink
    May 8, 2012
    334
    Thanks Received:
    271
    Bucks County, PA
    A portable scale is a cumbersome device but heck,... if that's what you want to do rather than have a tally of the information (per skid) from the shipper and properly space the loading (stagger) of the box then far be it for me to rock the boat.
    I'm doing the research and here's a couple of links to help you with your scale problem (man, am I happy to be in a tanker... don't miss THAT at all).
    http://scales-4-less.com/acatalog/Truck_Scale.html#a13
    Just google "Portable Truck Scale"... these things aren't cheap !!!
  6. snowwy
    Jul 6, 2009
    20,537
    Thanks Received:
    13,274
    your pretty funny. NOTTTTTTTTTTTTTTTTTTTTTTTTTTT.
    and i don't pull a box. nor do i haul skids.
  7. GAlanFink
    May 8, 2012
    334
    Thanks Received:
    271
    Bucks County, PA
    You're welcome... I'll make a note not to do what YOU should have done for yourself... RESEARCH.
    Funny or NOTTTTTTTTTTTTTTTTTTTTTTTTT,... I got your information.
    Next time,
    YOU GET IT.
  8. Starline
    Starline Medium Load Member
    Jun 1, 2011
    357
    Thanks Received:
    251
    Middle Tn
    I believe your wanting Right Weigh load scale for trucks.
    I have one of their original mechanical gauges (14 yrs old) on the trailer.
    These folks have come a long weigh... get it weigh ? HAHAHAHA I crack me up sometimes :biggrin_2559:
    http://www.rwls.com/
  9. Koolk
    Koolk Bobtail Member
    May 19, 2011
    42
    Thanks Received:
    7
    Richmond, BC
    We use Air-Weigh digital scales. They work great to convert air pressure to on the ground weight.
    Accurate to 300lbs. Been using them for the last 5 years. We were having the same problem on our dumps loading heavy. The air guages are too much guess work. A couple psi high and you could be 1000lbs over.
    Check out their website. Air-weigh.com
  10. SHC
    SHC Spoiled Rotten Brat O/O
    Feb 26, 2011
    8,484
    Thanks Received:
    7,046
    Westville, IN
    RightWeigh is what you want. They have a digital set-up that will give you the tractor and trailer weight in pounds and not PSI
