Isn't there space on top of the cab to put something?
Discussion in 'Questions From New Drivers' started by giantmonkey, Sep 11, 2010.
  1. giantmonkey
    giantmonkey Bobtail Member
    Sep 9, 2010
    34
    Thanks Received:
    5
    Sacramento, CA
    I saw often there is a wind guide (or some other name, anyway, I mean the peice of metal plate cover) on top of the cab so that the truck has better airodynamics. Thus it gives some space between it and the top of the cab. Is it allowed to put something there?
  2. Lilbit
    Lilbit Road Train Member
    Aug 4, 2008
    16,583
    Thanks Received:
    12,232
    Let me check my logbook
    Don't know about being able to put anything up there. Never had the need for that.
    It's called a dunce cap by most drivers, just so ya know.
  3. blackw900
    blackw900 The Grandfather of Flatbed
    Jul 12, 2009
    5,817
    Thanks Received:
    7,678
    A.W.O.L
    How much stuff are you plannin' on carrying with you?
  4. Lilbit
    Aug 4, 2008
    16,583
    Thanks Received:
    12,232
    If you end up down in the Laredo, TX area, make sure you check that area for uninvited passengers (illegals).
  5. Allow Me.
    May 28, 2009
    10,676
    Thanks Received:
    12,223
    Rancho Mirage, Ca.
    I put a bicycle up there when I was hauling furniture one time.
  6. Krooser
    Krooser Road Train Member
    Jul 25, 2010
    2,493
    Thanks Received:
    1,066
    Wisconsin
    Anything you carry on the truck must be secured according to DOT regulations... so if you DO carry something there must be 'rated' securement devices ...don't think there are many on the top of a tractor.
  7. REDD
    REDD The Legend
    Jun 29, 2009
    6,237
    Thanks Received:
    4,291
    Dueling Banjoville
    You can put some Mexicans up there at $500 a pop
  8. WAG
    WAG Bobtail Member
    Aug 11, 2010
    27
    Thanks Received:
    5
    mena ,ar
    I alway's called it the ATTIC
  9. lego1970
    lego1970 Medium Load Member
    Oct 10, 2008
    504
    Thanks Received:
    165
    Blue Springs, Missouri
    I used to carry a spare tire up there on one truck I drove and had it bungeed to one of the support brackets. Today I would use a strap instead. DOT never said anything, but that's not to say some nit-picky officer won't get all up tight about it.
  10. chompi
    chompi Road Train Member
    Jun 21, 2008
    5,653
    Thanks Received:
    3,485
    Deland, FL
    A lot of times that is where the satellite is mounted for your qualcomm. It is also going to depend on what truck you have. Some don't have them at all, some are very small. It would definitely be a pain in the butt to get to!
