Jake problem
Discussion in 'Questions From New Drivers' started by Mike36r!, Sep 2, 2019.
  1. Mike36r!
    Mike36r! Bobtail Member
    Sep 2, 2019
    Thanks Received:
    My truck runs fine with the Jake brake off but when Jake is on and it goes to engage it starts to jump back out and then in. No matter the setting or gear. Anyone have an idea as to what the problem is.
  2. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    Shop.
    A can of worms as to the possibilities starting at your fuse box for a loose or rusting fuse feeding power to the Jacobs.
  3. Powder Joints
    Sep 25, 2007
    7,687
    Thanks Received:
    7,785
    Rosamond, SoCal
    Turn off your cruise on the way to the shop,
    lovesthedrive and x1Heavy Thank this.
  4. Rubber duck kw
    Dec 9, 2017
    6,092
    Thanks Received:
    17,686
    Like the Jakes are turning on and off? Sounds like a connection type of problem to me, check the back of the switch.
    lovesthedrive Thanks this.
  5. HillbillyDeluxeTruck
    Mar 3, 2013
    5,933
    Thanks Received:
    30,328
    San Antone
    Thats how those jake brakes work on that type of truck.
  6. Collie
    Collie Guest
    With the jakes "ON", the wire connectors on the jake solenoids are wiggling with bad connection from the vibration. Remove your valve covers. The solenoids with the wires going to them will be in plain view. Pull the conectors off each jake solenoid and use pliers to crimp the connections better so they are tight when you reconnect them.
    I have lots of experience rebuilding jakes and jake diagnosis. On Cats though. IF its not a cat, check the soenoid wires anyhow.
  7. dibstr
    dibstr Road Train Member
    Sep 10, 2010
    1,308
    Thanks Received:
    932
    Have had to do that several times, on Cats of course.
  8. Collie
    Collie Guest
    how different can the other motors jakes be? All this new junk out there, probably very different
  9. Ridgeline
    22,420
    Thanks Received:
    116,710
    Go to the dealer and have them check it.
    FlaSwampRat Thanks this.
  10. Snow Monster
    Snow Monster Medium Load Member
    Feb 9, 2019
    543
    Thanks Received:
    1,297
    Besides the switches on the dash, you have switches on the throttle and clutch pedal too, if you have a clutch.
    Check those first to make sure they're adjusted properly.
