Jiffing 101 for yellow guys
Discussion in 'YRC' started by latanea, Feb 6, 2009.
  1. latanea
    latanea Road Train Member
    Sep 21, 2007
    1,337
    Thanks Received:
    235
    cincinnati (sharonville)
    _ton bundle and walleye Thank this.
  2. _ton bundle
    _ton bundle Road Train Member
    Jan 7, 2009
    1,230
    Thanks Received:
    936
    Elevator Bay, Minnesota
    They cut off first 45 minutes of that video which was that guy looking around the yard for a jiff- lock that actually worked!! They also cut the last 15 minutes of him taking a bath in zep to get all of the 5th wheel grease off of him!
    Why would you want video evidence of yourself breaking the golden rule of hostling... NEVER BREAK DOWN A TANDEM!!! That will get you stedy duty of hooking sets for the rest of your career in most yards! :biggrin_25525:
    Nice video. I'll have nightmares tonite for sure!
  3. walleye
    walleye Road Train Member
    Aug 21, 2007
    3,028
    Thanks Received:
    4,306
    Land of Cheese
    Cool,...I have only ever heard of those,..Never seen one that I am aware of,...Thanks for the vid Lat,....
  4. _ton bundle
    Jan 7, 2009
    1,230
    Thanks Received:
    936
    You ain't missing nothing. Those things suck bad. They never work right either. Getting the pintle lined up in -30 weather is enough to make a grown man cry (many have). There is about 1/2 inch margin of error to get that thing lined up (left, right, up and down!!). There should be a special ring in hell reserved for whoever designed that system.
    Of course, there are tricks to doing it and after about 100 times you figure it out, but none of the tricks are exactly 'easy' on the equipment. Also, if a certain truck and a certain jiff just don't want to get together, they wont, no matter what you try.
    Alot of guys have gotten hurt bad by those things.
  5. latanea
    Sep 21, 2007
    1,337
    Thanks Received:
    235
    if you have trouble with hooking one up - it is usualy because you are doing something wrong.
    once you get the hang of them - they are cool.
    also - if you get greasy - you are doing it wrong...
    (all to often guys are like bulls in China shops - and try and force them to fit etc etc - you have to be gentle)
  6. LandShark
    LandShark Road Train Member
    Nov 22, 2008
    1,525
    Thanks Received:
    1,064
    Riverdale, Ga
    ok i am going to show my ignorance here and its just because i have no exposure to this... What in world is a jiff....is it like turning a single screw in to a tandem?
  7. Coonass
    Coonass "Freshy Fresh"
    Sep 23, 2008
    1,080
    Thanks Received:
    1,179
    Yeah what is the point???
  8. Gondofini
    Gondofini Bobtail Member
    Feb 10, 2009
    23
    Thanks Received:
    6
    East Carondelet, ILL
    They suck, I worked for Roadway in 96. Work for Yellow now and hopefully they will get rid of Jifflocks.
  9. LandShark
    Nov 22, 2008
    1,525
    Thanks Received:
    1,064
    Riverdale, Ga
    great thats awesome BUT WHAT THE HELL ARE THEY
  10. latanea
    Sep 21, 2007
    1,337
    Thanks Received:
    235
    pretty much -
    the point is to have single axle tractors that can "convert" into a tandem axle (and therfore pull a heavy long box...) and vice versa...
    and you can take a "jiffed up" tractor with a set of doubles - and go pick up a long - or break down the jiff and hook a third trailer for your triples...
    think about it
    34K on tandems (wether they are drive axles or not) or 20K on a single axle....
