So I own a 2013 Volvo VNL 670. I need to know the official names of each key position. For example, once I put in my key, which way do I turn for which position? Also, which position should my key be in for me to use my Webasto and radio at night? Thanks!
The position the key is in when you put it in is off. Turn it counter clockwise is acc, accessory, turn it one position clockwise is on and turn it from there is start. Webasto should be unswitched, ie you should be able to turn it on without the key in the ignition. You will have to turn to acc to listen to the radio.
