knocking or slapping noise 05 volvo ved12. please help!!!!!
Discussion in 'Volvo Forum' started by Dickeyroberts, Jul 9, 2014.
  1. Dickeyroberts
    Dickeyroberts Light Load Member
    Feb 23, 2014
    138
    Thanks Received:
    30
    I last drove my truck a week ago today and it was fine. No noise and ran great. checked my oil today and it was full. started my truck up today and its making a knocking noise. if I rev it a bit and get to 1200 rpms it goes away but comes back after its lower than 1200 rpms. kind of running crappy too. its not blowing any smoke. Anyone have this same problem with their truck. any help would be greatly appreciated. 05 Volvo with a ved 12 and it has 739000 miles on it. the mechanic at the garage I park at said he thinks it might be a bad injector and that it has a dead cylinder. Could that be right? Im panicking here!
  2. Dickeyroberts
    Feb 23, 2014
    138
    Thanks Received:
    30
    I also forgot to mention that there is no codes or check engine light on
  3. Scania man
    Scania man Road Train Member
    Jul 1, 2011
    2,199
    Thanks Received:
    483
    Saskatchewan
  4. Dickeyroberts
    Feb 23, 2014
    138
    Thanks Received:
    30
    Thank you very much. I sure will
  5. CondoCruiser
    CondoCruiser The Legend
    Apr 18, 2010
    19,726
    Thanks Received:
    18,734
    Tennessee
    If it's not blowing smoke is a good sign. If the mains were shot the cylinders take on an egg shape, wear the rings out and you'll get blow by and burn oil. It's probably a dead cylinder like he said.
    Dickeyroberts Thanks this.
  6. Dickeyroberts
    Feb 23, 2014
    138
    Thanks Received:
    30
    Thanks condo cruiser! You made me feel a lot better!
  7. Duramaxxed
    Duramaxxed Light Load Member
    Jan 2, 2012
    155
    Thanks Received:
    60
    Bourbonnais, IL
    Does it have Jakes on it? Sometimes the leaf spring breaks and causes the engine brake rocker arm slap between valve bridge and the cam lobe. Super common if it's been a while since an overhead set. Also could be a cam issue. No smoke tells me it's probably not an egr or fuel issue. Usually if it is knocking due to injector it would be smoking white. Same with a stuck open egr causing overfueling, you can smell fuel.
    KB3MMX and Dickeyroberts Thank this.
  8. Dickeyroberts
    Feb 23, 2014
    138
    Thanks Received:
    30
    Yeah it does have a jake on it.
  9. Duramaxxed
    Jan 2, 2012
    155
    Thanks Received:
    60
    Bourbonnais, IL
    If the noise sounds like it's under the valve cover check the leaf springs. Keeps the rocker from slapping.
  10. Dickeyroberts
    Feb 23, 2014
    138
    Thanks Received:
    30
    Is that expensive fix duramaxxed?
