light bulb help
Discussion in 'Kenworth Forum' started by damutt, Aug 30, 2015.
  1. damutt
    damutt Road Train Member
    May 6, 2013
    1,126
    Thanks Received:
    370
    ok i got a few stupid questions.
    i got a 2005 t600 , need to replace the flourescent dome light. do you happen to know what the size is and how to get the stupid cover off.
    TIA
  2. 062
    062 Road Train Member
    Oct 20, 2013
    6,205
    Thanks Received:
    33,431
    Not been in a T600 in awhile,but the cover should have a little play one way or the other. Just slide as far one way as it will go,then use a thin screwdriver or pocket knife to gently pry out about 1/3 way from either end. Size will be on the bulb.
  3. damutt
    May 6, 2013
    1,126
    Thanks Received:
    370
    ah ok thank you much sir
