Light Problem
Discussion in 'Peterbilt Forum' started by kwforage, Aug 9, 2012.
  1. kwforage
    kwforage Road Train Member
    Jun 3, 2007
    1,047
    Thanks Received:
    472
    Wisconsin
    I have a 94' 379 that the lights work fine on low. The problem is when I hit the high beams not only does the passenger side one not come on, but the low beam on that side goes out . Also the high beam indicator does not work. I pulled the bulbs out and checked the wiring and bulbs and all looked good. Changed a relay in the fuse panel and the lights and indicator worked briefly, not they don't again. Any ideas?
  2. Wildman8492
    Wildman8492 Bobtail Member
    Aug 10, 2012
    Thanks Received:
    Check to be sure you have the correct head lights in the truck.sounds to me like wrong ones.
  3. tirednaz
    tirednaz Heavy Load Member
    Oct 4, 2011
    838
    Thanks Received:
    430
    Arizona
    I think you might have a bad switch
