light problems
Discussion in 'Freightliner Forum' started by itswrongway, Mar 30, 2015.
  1. itswrongway
    itswrongway Bobtail Member
    Oct 22, 2006
    9
    Thanks Received:
    2013 cascadia . the fuse block was changed and now my bunk dome light don't work and the fog or driving lights don't work . also the marker light interrupter button works but not the way it was . example press button once the lights blink 3 times by them self it didn't use to do that . press once blink once . my turn signals work different to. right or left turn use to blink 3 times with gentle nudge of the switch now they blink once only . was something hooked up backwards or something not hooked up ? yes all the fuses are good . where should i look to see if plugs are hooked up wrong or not hooked up ????????????????? thanks to anyone that understands what i am talking about and can give me a answer ...
  2. mhyn
    mhyn Road Train Member
    Dec 29, 2008
    4,255
    Thanks Received:
    4,515
    Northridge, CA
    Fuse block? the one behind glove box ?
