Load Straps, Chain/Straps. Chains. What type/size to buy
Discussion in 'Heavy Haul Trucking Forum' started by UltraZero, Mar 6, 2014.
  1. UltraZero
    UltraZero Medium Load Member
    Jul 18, 2013
    406
    Thanks Received:
    96
    Good day folks. I was doing research for equipment to put on my truck.
    I currently have standard 30' straps, 5/16 chains, chain binders.
    I think these load securement devices are ok. for lite weight loads, but, not great for heavy loads.
    Can work for heavy loads, but based on working load limits, I will need alot to secure heavy equipment.
    What are your thoughts.
    Should I consider 1/2" chain, 1/2" binders, heavy duty straps above 5400 lbs ??
    Do any of you folks have longer straps then 30"
    What about load tarps?? Where to buy GOOD tarps.
    Thanks
  2. dhooks
    dhooks Light Load Member
    Jun 25, 2012
    159
    Thanks Received:
    52
    What do you haul, thats fine for just about all general freight.
  3. UltraZero
    Jul 18, 2013
    406
    Thanks Received:
    96
    Well, currently, general freight, containers, equipment. Looking forward to down the road, when I need to haul heavier equipment. Large earth movers, Farm Equipment, etc. Then I hope to get into heavier items. I don't really want to waste money buying things for now, and later have to re buy equipment. I'm sure I should purchase new equipment after usage after time.
  4. dhooks
    Jun 25, 2012
    159
    Thanks Received:
    52
    I prefer 3/8s for flat bed and 6 axle step and rgn, but 5/16s really is,ok
  5. UltraZero
    Jul 18, 2013
    406
    Thanks Received:
    96
    Good to hear. I was looking at 1/2 chain. The extra weight is an additional 500lbs to 1,000 lbs on the truck for the chains I would carry.
  6. HighCountry
    HighCountry Light Load Member
    Feb 27, 2014
    172
    Thanks Received:
    301
    Stephenville, Texas
    Depends entirely in the weight of what your hauling. 5/16 are good for tying down dunnage/tarps. Small pieces. You have to do the math with our chain ratings and weight of load. Be very careful with this!!! For your own safety, and You will be checked. Me jus 3wks ago in Ok. Very through, checked rating on hooks, chains and stretch links. All good
    my 2cents....start out all g-7's, 6-20' 3/8...6-10' 3/8...6-4" straps w/ratchets.
    about 15 3/8 ratchet binders you'll need the extras. I avoid snap binders, seen to many friends get hurt w them.
    NEVER EVER!!!! Skimp on safety...and you'll make it thru the learning curve..
    tarps?? Aren't those some kind of fish?
    good luck.
  7. UltraZero
    Jul 18, 2013
    406
    Thanks Received:
    96
    I don't like tarping as well.
    I was thinking of 1/2 chains, binders, 6600lb tie straps. I don't want any securement issues with the DOT. I like to keep them on my side. LOL..
    Sounds good to me. on the quantity. What about straps with hooks??
  8. TripleSix
    18,897
    Thanks Received:
    132,330
    If you're not pulling an RGN or a heavy duty stepdeck with 10000WLL D Rings, there's really no point in buying 1/2 inch chain. Most flats and steps have a 6000-6600 lb WLL rating on their rings, spools and pockets. What's the point in carry around big chain when you will still need the same number of securement points as 3/8 chains?
  9. king Q
    king Q Road Train Member
    Jul 26, 2010
    2,880
    Thanks Received:
    3,032
    Johannesburg sa
    When I was still driving I used to use 1/2 and 3/8 lifting grade on the oversize/weight loads we did.
    On our general cargo flats we use 3/8 chain and binders as we do on our heavy haul units but on the heavy haul units these are of lifting grade.
    The difference in price is about 400% but no point in using this on general type trailers as stated before the limited rating of the lashing points render the extra on rating on the chains pointless.
  10. UltraZero
    Jul 18, 2013
    406
    Thanks Received:
    96
    Hmm. So, grade 80 /grade 100 chain is more like what you are talking about?????
