Local dump work
Discussion in 'Ask An Owner Operator' started by Logan76, Feb 13, 2011.
  1. Logan76
    Logan76 Crusty In Training
    Jul 12, 2009
    4,528
    Thanks Received:
    17,698
    kittanning, PA
    Quick question, If you were to buy a dump truck for local work (tri-axle), would you buy a steel body or aluminum? Either truck your going to limit what kind of work you can do effectively. I'm just curious what ya'll think. thanks.
  2. ampm wayne
    ampm wayne Heavy Load Member
    Jan 13, 2009
    945
    Thanks Received:
    746
    bloomington,in
    I would buy a steel bed.
    An aluminum bed is an advantage if you are going to get paid by the ton.
    Steel beds are more versatile. You will be able to use your truck on a vast variety of job sites.
    I think you will be far less limited if you go with a steel bed.
  3. Logan76
    Jul 12, 2009
    4,528
    Thanks Received:
    17,698
    kittanning, PA
    That's what I was thinking myself, the only thing I couldn't haul with the steel bed would be coal, and it's harder to get that work around here anyhow.
  4. rbht
    rbht Heavy Load Member
    Jan 23, 2010
    888
    Thanks Received:
    525
    CT,NH
    My fahter and brother have 1 steel and 1 alum body and they both stand up about the same, the alum dump has a liner on the floor and half way up and have never had an issue with it. They haul everything from sand and gravel to stone, stumps and rip rock/large rock. If your going to haul alot of lagre rock or demo i would definatly go with steel but for everyday general construction alum will work just fine and save some wieght.
