Logbook rules
Discussion in 'Questions From New Drivers' started by terryjoromero, Jan 13, 2013.
  1. terryjoromero
    terryjoromero Bobtail Member
    Jan 13, 2013
    Thanks Received:
    If I drive my rig from home to a yard to pick up my trailer, Do I start driving time at my home or after I pick up the trailer? Its an hours drive to pick up trailer. So Im using 2 hours of my drive time there and back daily.
  2. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    Dec 8, 2012
    2,906
    Thanks Received:
    49,191
    hunting...../ retired
    Are you being paid to go get the trailer? if you are your time starts when you move that tractor. I think the rules say that if you are to be compensated for the time/and or miles then they must be logged.
  3. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,553
    Thanks Received:
    13,281
    so does that mean i DON'T have to log my loading times.
    cuz i don't get paid for strapping and tarping. i only get paid to drive.
  4. windsmith
    windsmith Road Train Member
    Sep 2, 2011
    7,296
    Thanks Received:
    6,031
    NEPA
    Read the regs and the interpretations, it's all there for you:
    J_FROG Thanks this.
  5. J_FROG
    J_FROG Road Train Member
    Sep 4, 2011
    1,061
    Thanks Received:
    564
    49 states and Canada
    Since most tarping is a requirement of of flat bedders job and would believe that your compensation is part of your per mile pay although many companies pay extra to do so. If you can't find it in the regs email Old blue.
  6. windsmith
    Sep 2, 2011
    7,296
    Thanks Received:
    6,031
    NEPA
    No. No. and, No.
    Thanks for playing.
  7. dptrucker
    dptrucker Road Train Member
    May 14, 2012
    4,681
    Thanks Received:
    3,197
    adelanto,ca.
    to the op.. you can log off duty driving on the way home since you are releived of duty. but drive back has to be logged driving since you been dispatched on a load.
  8. dude6710
    dude6710 Road Train Member
    Mar 26, 2010
    2,162
    Thanks Received:
    622
    MN
    So then how do you explain to the dot for the change of place between the off duty and your start of day because there not at the same place?
  9. windsmith
    Sep 2, 2011
    7,296
    Thanks Received:
    6,031
    NEPA
    Off-duty driving. I've never been questioned, and I even received a level 3 while driving bobtail off-duty. The officer didn't even blink.
  10. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    Oct 1, 2007
    1,871
    Thanks Received:
    1,090
    Duncannon, Pa
    Similarly, time spent traveling short distances from a driver's en route lodgings (such as en route terminals or motels) to restaurants in the vicinity of such lodgings may be considered off-duty time. The type of conveyance used from the terminal to the driver's home, from the driver's home to the terminal, or to restaurants in the vicinity of en route lodgings would not alter the situation unless the vehicle is laden. A driver may not operate a laden CMV as a personal conveyance.
    Based on the above exerpt the drive to your home AND the return to the terminal would qualify as personal conveyance and therefore could be logged as "off duty."
    Now the interpretaion of "laden" and "unladen" has many drivers confused. Some drivers will claim personal conveyance when pulling an empty trailer while others will only use the personal conveyance exemption when bobtailing.
    I use my truck for personal conveyance ONLY when bobtailing AND when the distance is within 30 miles.
    Busasamurai Thanks this.
