Looking for a 3 way valve. 3 inches. 1 in-2 outs.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by snowwy, Feb 28, 2021.
  1. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,568
    Thanks Received:
    13,293
    Is there such a thing?
    Google isn't helping.
    Got one pipe to load. I'm looking to keep the overhead load hooked up. Slower. But I want to be able to vacuum load also. Faster.
    Some of our trailers are gravity. So those guys need to overhead load. Mine is vacuum.
    A way to close off one or the other. Depending on who's loading. Both outlets aren't open.
    Hopefully a way to suck air to clean out the hose before disconnecting. So you switch the valve from vacuum to close it off and back over to the pump for overhead. Open another valve to suck in air.
    All I'm finding is the standard in and out valve. Open or close.
  2. Roberts450
    Roberts450 Road Train Member
    Feb 6, 2016
    2,237
    Thanks Received:
    3,636
  3. snowwy
    Jul 6, 2009
    20,568
    Thanks Received:
    13,293
    Yes sir. Thank you.
    Looks like diverting is what I need.
  4. FLHT
    FLHT Road Train Member
    Aug 2, 2014
    1,402
    Thanks Received:
    2,466
    Mountain States Supply in SLC
    May want to look into PVC valve.
    Brass aint cheap
    snowwy Thanks this.
  5. RockinChair
    RockinChair Road Train Member
    Feb 19, 2012
    5,136
    Thanks Received:
    12,994
    CC, TX
    PVC may not be able to handle the pressure and vacuum OP will be putting through that valve.
  6. FLHT
    Aug 2, 2014
    1,402
    Thanks Received:
    2,466
    What kind of pressure we talking about ? I got no idea
    Class 300 PVC will handle 700psi
  7. snowwy
    Jul 6, 2009
    20,568
    Thanks Received:
    13,293
    1. No idea on pressure. They got 2 pumps. My trailer is 7000 gallons. 1 pump fills it in 35 minutes. The other spare pump is way slower. It don't spin as fast.
    As far as me sucking. It's the same time as the faster pump.
    GPH is about 12,000.
  8. RockinChair
    Feb 19, 2012
    5,136
    Thanks Received:
    12,994
    CC, TX
    What kind of trailer is this, and what kind of product are you putting in it?
  9. snowwy
    Jul 6, 2009
    20,568
    Thanks Received:
    13,293
    Beer, whey, liquid sludge, etc.
  10. FLHT
    Aug 2, 2014
    1,402
    Thanks Received:
    2,466
    So whatever you do it must be food grade ?
