loosing coolant from cap also burning oil
Discussion in 'Freightliner Forum' started by joshgmfan1993, Apr 17, 2016.
  1. joshgmfan1993
    joshgmfan1993 Bobtail Member
    Apr 17, 2016
    4
    Thanks Received:
    Hello everyone, I have a Frieghtliner Cascadia DD15, if yall can help me know what's exactly going on with my truck. I'm loosing coolant from my cap. I only have 450k miles on motor. Burning about a gallon every 5k to 7k miles. Haven't taken to the shop yet. Have a yellow engine light stays on for a bit before I start the engine. Goes away after I start up
  2. Superhauler
    Superhauler TEACHER OF MEN
    Jan 30, 2010
    12,209
    Thanks Received:
    100,735
    keep stroking.
    burning or pushing it out? check rad cap, if ok then you may have a head gasket blown or cracked head, or liner issue. GET IT FIXED BEFORE YOU TOAST YOUR ENGINE!
    joshgmfan1993 Thanks this.
  3. joshgmfan1993
    Apr 17, 2016
    4
    Thanks Received:
    It's pushing it out
  4. heavyhaulerss
    Dec 23, 2009
    3,723
    Thanks Received:
    2,040
    AL/TN BORDER
    when mine pushed coolant out turned out to be head gasket.
  5. joshgmfan1993
    Apr 17, 2016
    4
    Thanks Received:
    Thanks for the replys, does warranty cover the head gasket?
  6. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    Jan 23, 2013
    1,706
    Thanks Received:
    1,893
    Fort Worth, Tx
    True factory warranted will, extended warranty/used truck Freightliner warranty normally only covers "hard" parts.
  7. uncleal13
    uncleal13 Road Train Member
    Apr 9, 2009
    3,797
    Thanks Received:
    6,299
    Humboldt, Sk
    Should be covered if you have extended warranty, good to 500,000 miles or five years.
  8. HopeOverMope
    HopeOverMope Road Train Member
    Feb 25, 2016
    1,801
    Thanks Received:
    3,211
    I-20 LOUISIANA
    I wouldn't volunteer the info that You've been driving it like this for X amount of days, may be used against you. When it comes to neglect, they don't like to pay up, which is understandable. Coolant is not supposed to be pushed out of the overflow tank. More times than not, that's not a good sign. Usually it's exhaust gas leaking in from what I know. I'm not sure if an exhaust leak will cause the coolant to get into the oil but You don't want that coolant getting into your oil, hydro locking the engine and etc. white smoke out the stack after warming up to operating temps has been known to be from coolant leaking into oil, usually not a good sign.
    magoo68 and joshgmfan1993 Thank this.
  9. joshgmfan1993
    Apr 17, 2016
    4
    Thanks Received:
    A bad head gasket can cause the oil to burn also?
  10. mhyn
    mhyn Road Train Member
    Dec 29, 2008
    4,255
    Thanks Received:
    4,515
    Northridge, CA
    my 2012 dd15 stopped at 451k. i had bad liner seals.. overhaul was done under warranty. take your truck to nearest detroit diesel distributor not freightliner dealer
