Loosing Coolant slowly from top of the tank.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OFilippov, Feb 23, 2023.
  1. OFilippov
    OFilippov Bobtail Member
    Oct 2, 2014
    40
    Thanks Received:
    13
    Hi guys.
    Cascadia 2016 here with Detroit engine. Couple weeks ago noticed slow lost of a coolant that looks like coming from under the top cap. Got the cap replaced with no changes. Own the truck for about 2 years and never seen anything like this before. Also if I recall correctly, the overfill portion of the tank on the left bottom was empty. Not anymore.
    Any suggestions on what could be wrong?
    Thank You.
  2. JB7
    JB7 Heavy Load Member
    Dec 13, 2022
    952
    Thanks Received:
    1,642
    Laurel, MD
    1 - What comes out of your air tanks when draining? Check the air compressor output line. Remove it and see if it is dry or if there is coolant there. You can also run the engine with the line off. Combustion can get into cooling system through the air compressor 2 - cracked engine head or blown head gasket 3 - leaking EGR cooler though more likely to only lose coolant with a leaky cooler.
    With Cummins the coolant comes in direct contact with the cylinder liner and if pitted bad enough combustion can get into the cooling system that way.
    D.Tibbitt and RubyEagle Thank this.
  3. RubyEagle
    RubyEagle Medium Load Member
    Apr 17, 2010
    632
    Thanks Received:
    790
  4. Dave_in_AZ
    59,327
    Thanks Received:
    411,656
    Clean that off and inspect that surge tank. It may be cracked.
    Once they go, the radiator will follow within a week or two.
    They both are very thick plastic. Radiator is thicker.
    After so many years, they fatigue from expanding and contracting.
    The surge tank goes first. Then after you replace it, because it's new and very rigid, the fatigued spot(s) in the Radiator go.
    RubyEagle Thanks this.
  5. JB7
    Dec 13, 2022
    952
    Thanks Received:
    1,642
    Laurel, MD
    Possible, but look closely at what he said. And yes, check the simple things first.
    "...coming from under the top cap"
    "the overfill portion of the tank on the left bottom was empty. Not anymore."
    Sounds like excessive pressure in the system.
