M2 MBE 900 carbon packing -- Is a new engine the only solution?
Discussion in 'Freightliner Forum' started by M2ambo, Dec 26, 2019.
  1. M2ambo
    M2ambo Bobtail Member
    10
    Dec 26, 2019
    Our 2009 M2 with an MBE 926 with around 125,000 miles wouldn't start recently after sitting for several months. It was towed to the dealer, who reported that it needed a new engine ($41,000) because of carbon packing. Any thoughts on the following diagnosis (and ideas about things to try) would be very appreciated.
    Troubleshoot crank, no start condition:
    VERIFIED CUSTOMER COMPLAINT, TRUCK WILL CRANK BUT NOT START. GOT LAPTOP AND CONNECTED WITH DL. NO FAULTS. HOOKED UP AIRLINES AND AIRED TRUCK UP. PUSHED INTO SHOP. GOT FUEL SYSTEM PRIMER AND HOOKED UP. PRIMED FUEL SYSTEM AND TRIED TO START WHILE PRIMING. STILL WOULDN'T START. MONITORED FUEL COMPENSATION PRESSURE, ACTUAL FUEL MASS, AND KW/NW SIGNAL WHILE CRANKING. FUEL COMPENSATION PRESSURE GOT UP 50 PSI (REPRESENTS LOW SIDE FUEL PRESSURE). 50 PSI IS GOOD CRANKING PRESSURE. KW/NW SIGNAL WENT FROM OFF TO ON, WHICH IS CORRECT. ACTUAL Ft:EL MASS WENT OVER 100 MG/ST, ACTUAL FUEL MASS GOT EXCESSIVELY HIGH AND ENG[NE STARTED FUEL KNOCKING. EXHAUST HAD GAS SCENT TO IT. RAN RELATIVE COMPRESSION TEST, FOUND CYLINDERS 2,3, AND 4 WERE VERY LOW. NEED TO RUN MECHANICAL COMPRESSION TEST TO VERIFY CYLINDERS ARE NOT DAMAGED DUE TO OVER FUELING. MECHANICAL TEST CONFIRMED MULTIPLE CYLINDERS HAVE VERY POOR COMPRESSION. A NEW ENGINE IS NEEDED.
    Troubleshoot low compression:
    PUT JUMP STARTER ON TRUCK TO GET TO CRANK EVEN CRANKING YOU CAN HERE WAY IT CRANKS LOW ON COMPRESSION RINGS ARE STUCK BECAUSE OF CARBON PACKING (OIL) YOU CAN PULL PISTONS AND CHANGE RINGS IF CYLINDERS OK.
  3. AModelCat
    164,924
    If cylinders have low compression, unfortunately you'll have to have the engine opened up.
  4. M2ambo
    10
    Dec 26, 2019
    Opened up meaning replacement? Or opened up meaning take the cylinder head off, drop in some kind of solvent to dissolve the crud that's fouling the piston rings, and reassemble? Or opened up meaning pull the pistons from the crankshaft, then clean and replace them?
    And would there be any reason that Mercedes might help us with the cost on this?
    Thanks.
  5. AModelCat
    164,924
    Opened up as in pull the head and see what's up. Could be carbon packing, scored cylinder walls, broken rings etc. I'm not familiar with Mercedes but I wonder if it'd be possible to run a borescope down and look at the cylinder walls without taking too much apart?
    Engine's 11 years old. Might be able to push for goodwill due to low miles. They might help out a bit but don't bet the farm on it.
  6. M2ambo
    10
    Dec 26, 2019
    Many thanks. Will check with the higher-ups and see how they want to proceed.
  7. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Don't understand why a piston and cylinder kit couldn't be done.
    Or is that not possible with mercedes?
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    If there is no compression then find the reason. If you find the reason likely it will be a fatal one.
    I agree it will need a new engine. The engine is very sick if it cannot burn relatively clean.
  9. rolls canardly
    rolls canardly Road Train Member
    1,643
    4,172
    Feb 7, 2009
    mt. pocono. pa.
    Dealer, (Stealer,) gave my first engine the sign of the cross - it's all over,
    and I had it towed home.
    Took the head off, and did a complete valve replacement and re-seat.
    Planed head, added New head gasket, and away I went.
    Sure, it leaked oil into the water from #5, but I used it long enough to save up to get
    a brand new short block from Caterpillar, not Freightliner, for about 5 grand.
    Purrs like a little kitty cat, and brand new short block was the way to go for me.
    I'm not paying crazy money to the dealers for something I can do myself.
    baha and x1Heavy Thank this.
  10. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I have a engine that smokes itself. A little crate 350. Its not much of a engine as engines go this one being the third one in my 270,000 mile vehicle. (A survivor of the junk for cash era) I follow one particular rule, take her out for a run sufficient to blow the carbon out. If you let her sit and idle she will smoke all over herself then carry a misfire on cylinder 5 to start off followed by hard to start.
    In my case it takes a replacement of plugs and so on. The engine bay is relatively clean so the issue is internal related to how hard it is working and it needs to be working relatively hard on a run.
    Fuel treatments help as does fresh gasoline on my end. One future shop work will involve a new coil that is stronger than OEM in output to each plug. So when you have fast accurate and more importanly big fire then it will have no choice but to burn it out.
  11. M2ambo
    10
    Dec 26, 2019
    Thanks for all this great info. I should point out that this engine is in an ambulance, which does (or maybe I should say "did") a lot of short runs and spent a lot of time at idle, which is necessary to keep the heat or ac running until the crews return with a patient (for what it's worth, the unit even had a special switch installed that would allow it to stay running after the key had been removed while the crew was providing medical care on scene, with the provision that if someone hopped in and tried to steal the unit, the engine would shut down the first time the brake pedal was pressed).
    It did get spooled up pretty hot once in a while to do a regen, but apparently not frequently enough (I can only imagine what it would have been like had we elected to bypass the regen system which EPA allows on emergency vehicles).
    With all of that said, one would think that Mercedes would design an engine that could put up with any operational style and not just assume that everybody was going to be running for hours non-stop every day.
    And I still don't get why this problem appeared all of a sudden after the vehicle had sat unused for several months.
    Hulld Thanks this.
