Major sparks when reconnecting batteries
Discussion in 'Questions From New Drivers' started by Frank J Mannuzza, Nov 6, 2011.
  1. Frank J Mannuzza
    Frank J Mannuzza Bobtail Member
    Nov 6, 2011
    5
    Thanks Received:
    Chelmsford,Ma
    I have a Volvo 1999 VNL.My batteries died because I left an interior light on for several days. After successfully charging ( I had disconnected the positive cables but not the negative ones ) I tried to reconnect the cables to the baterry bank which resulted in major sparking. I removed the negative cables, reconnected the positive cables and tried to reconnect the negative ones which resulted in major sparks and a whirring sound from the engine.
    Can anyone diagnose my problem?
    Thanks for your help.
  2. Working Class Patriot
    Working Class Patriot Road Train Member
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Wherever and Whenever...
    You'll get arcing from connecting or disconnecting batteries.....That's normal....
    The engine sound...Your starter solenoid closed?
  3. otherhalftw
    otherhalftw R.I.P.
    Nov 18, 2008
    13,081
    Thanks Received:
    45,332
    CA...gold discovery foothills
    You got one backwards!
  4. otherhalftw
    otherhalftw R.I.P.
    Nov 18, 2008
    13,081
    Thanks Received:
    45,332
    C'mon...even in MA...it's after noon....should be open....maybe late hours for Sunday!:biggrin_25522:
  5. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Yep....I missed that....Good catch....:biggrin_25514:
  6. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Nope...NM and AZ...No running on Sunday...for me anyway....:biggrin_2551::biggrin_25516:
    otherhalftw Thanks this.
  7. Frank J Mannuzza
    Nov 6, 2011
    5
    Thanks Received:
    Chelmsford,Ma
    Thanks for the quick replies.
    It is definitely wired correctly since the cables are so stiff, color coded and of a limiting length it would be nearly impossible to screw up the cable connections.
    It does sound like the solenoid is stuck open or a relay is open(?). Every time I touch the negative, heavy cabled ground to the battery there's definitely the sound of a motor turning over.
  8. albhb3
    albhb3 Medium Load Member
    Nov 3, 2009
    596
    Thanks Received:
    279
    I tell ya what will fix it take a metal cresent wrench and touch both terminals at once. :biggrin_25519:
  9. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Oh yeah...that sure will "Fix" something alright....:biggrin_2554:
  10. Wedge
    Wedge Road Train Member
    Jun 20, 2010
    1,831
    Thanks Received:
    1,583
    Griffin, Georgia
    If your tractor is equipped with a load disconnect switch, try shutting that down before connecting your cables.
