Marker interrupt
Discussion in 'Volvo Forum' started by flightwatch, Apr 13, 2016.
  1. flightwatch
    flightwatch Road Train Member
    Jun 22, 2011
    1,234
    Thanks Received:
    1,200
    Somewhere in Texas
    2016 670. Is there any way to easily change the marker interrupt switch to flash all of the lights (minus the headlights obviously) instead of just the clearance lamps. The trailers that I pull have the clearance lamps and side markers on the same circuit... So they don't blink when the switch is pressed. It makes the marker interrupt feature useless.
    bbechtel16 and silver dollar Thank this.
  2. TheDude1969
    TheDude1969 Heavy Load Member
    Jun 10, 2013
    807
    Thanks Received:
    823
    Joliet, Il
    The easiest way I know of is to take apart your pig tail and switch the marker/parking lamp wires (phillips screw driver). My 2012 used 20amp fuses for both so hopefully that won't be an issue for you in 2016.
    flightwatch Thanks this.
  3. flightwatch
    Jun 22, 2011
    1,234
    Thanks Received:
    1,200
    Somewhere in Texas
    Thanks. I'll give that a try.
  4. silver dollar
    silver dollar Medium Load Member
    Jan 31, 2009
    481
    Thanks Received:
    210
    Central North Carolina
    Did you get a chance to switch the wires on you lights? My 06 is the same way, and I'm looking to correct mine also.
  5. flightwatch
    Jun 22, 2011
    1,234
    Thanks Received:
    1,200
    Somewhere in Texas
    No. I've been too busy. I did ask a ta tire changer and he said it was not very easy to do. Me and electrical wiring have never gotten along, so I'm a bit nervous to take it on... Especially if it not a very easy task.
    silver dollar Thanks this.
  6. TheDude1969
    Jun 10, 2013
    807
    Thanks Received:
    823
    Joliet, Il
    This may help you both:
    Reason for edit: better video
  7. Ridgeline
    22,379
    Thanks Received:
    116,154
    I think this all happens through the body computer which means it has to be programmed if it is even possible.
    joealbergo and silver dollar Thank this.
  8. silver dollar
    Jan 31, 2009
    481
    Thanks Received:
    210
    Thanks. Informative video; but I think I have to find it any of the leads interrupt with the switch, then I will know which ones to switch. Thanks again.
  9. silver dollar
    Jan 31, 2009
    481
    Thanks Received:
    210
    I never thought of that. That may be the case, since there is no other reason I've seen to put an intrupt switch on a tractor, and it only interrupt the tractor lights. Maybe another way Volvo can get $$$ to reprogram it. Thanks for the reply.
  10. flightwatch
    Jun 22, 2011
    1,234
    Thanks Received:
    1,200
    Somewhere in Texas
    Could be. I'll find out Monday when I call them.
