Mud flaps must be at the rear of the trailer
Discussion in 'Trucking Industry Regulations' started by true blue, Nov 1, 2015.
  1. true blue
    true blue Medium Load Member
    Jul 13, 2011
    304
    Thanks Received:
    231
    Harrisburg, NC
    Can anyone tell me which state it is that fines truckers for not having the mudflaps at the very rear of the trailer (at the ICC bumper)? Someone told me about it a few years back and though I haven't run across that state line (otherwise, I'd have been fined), I'd like to make sure I don't cross into that state without being prepared. I mostly pull a stepdeck, but occasionally pull a rented van.
    Chinatown and lots of character Thank this.
  2. truckon
    truckon Swamp Thing
    Dec 16, 2011
    4,774
    Thanks Received:
    15,917
    Like I'd tell you!
  3. Fajo
    Fajo The Dark Knight
    Jan 26, 2013
    2,214
    Thanks Received:
    2,352
    Boise, ID
    According to google, to get there you go to LA and rent a rowboat. Enjoy driver.
  4. MACK E-6
    48,765
    Thanks Received:
    225,329
    Nah. Just put a little more air in the tires. That should make a truck float. :)
    S M D, Fajo and truckon Thank this.
  5. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    74,676
    Thanks Received:
    169,790
    Henderson, NV & Orient
    Contact OOIDA and someone there can probably answer your question.
    www.OOIDA.com
  6. true blue
    Jul 13, 2011
    304
    Thanks Received:
    231
    Harrisburg, NC
    You must be desperate for posts, "truckon"
  7. true blue
    Jul 13, 2011
    304
    Thanks Received:
    231
    Harrisburg, NC
    Chinatown, I have contacted OOIDA and NASTC. Both weren't aware of which state.
  8. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,539
    Thanks Received:
    13,275
    I tbink its a fed regulation to have em behind the tires. Covering half the height if tire. At least.
    I was told that by a previous employer. A few years back so laws may have changed since.
    48 foot spreads will have em mounted to bumber in most cases. As the rear tire sits by the bumper. As well as some other specialized trailers. If you look at standard trailers with sliding axles. They'll all be mounted behind the tire.
    BUT. I just saw a 53 van with em mounted to the bumper. And the axles were all the forward.
    States seem to have their own interpretation of the fed rule. Like texas will write you up if they're flapping in the wind. Even though their own locals will have flaps flying around.
  9. Ridgeline
    22,368
    Thanks Received:
    116,046
    The regs haven't changed, it is the same as it has been, the fmcsa little book has the reg, the states all have fines,
    truckon Thanks this.
  10. Skate-Board
    Skate-Board Road Train Member
    Aug 9, 2014
    3,801
    Thanks Received:
    3,996
    Merrimack, NH
    I met a trucker parked next to me in AZ. I'm looking at the side of his truck trying to figure out where he was based and was confused. He came out and I asked him. He said Hawaii. I was like WTF???? He comes over every year and does the art show. His trailer is very special with all sorts of stuff like AC, heat, dehumidifier, humidifier and tons of other stuff.
    true blue Thanks this.
