Multi-function printer For OTR
Discussion in 'Questions From New Drivers' started by CAM, Oct 22, 2010.
  1. CAM
    CAM Light Load Member
    Oct 8, 2010
    73
    Thanks Received:
    14
    Oregon
    I'm buying a new laptop to take OTR with me, and along with it I can get a heck of a deal on a Multi-Functon printer, will I actually use it, or will it just take up space?
  2. statikuz
    statikuz Medium Load Member
    Jun 22, 2009
    401
    Thanks Received:
    140
    Reno Nevada
    It will just take up space until you desperately need it. :)
    You can use it to receive faxes via e-mail, say for expired permits, trailer registrations, etc., you can also use it to scan in receipts or the odd thing that you might need to send in - if your company uses Transflo and subscribes to it, you can use it to Transflo your paperwork without having to find an equipped truckstop.
    CAM Thanks this.
  3. CAM
    Oct 8, 2010
    73
    Thanks Received:
    14
    Oregon
    Thanks Statikuz for the quick response,
    Maybe I'll go ahead and get it, then just leave it home until I actually have a need for one. My wife and I are planning to team drive, and I'm sure space will be very limited.
  4. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    Jul 23, 2007
    28,291
    Thanks Received:
    44,445
    Midwest
    If you get a wireless, and your laptop has wireless, then you don't have to worry about cords. We bought a Lexmark for the truck that's wireless, and like it very much. Walmart has several options for wireless printer combos.
    Kansas and CAM Thank this.
  5. Jfaulk99
    Jfaulk99 Road Train Member
    May 16, 2009
    2,914
    Thanks Received:
    1,652
    Couch
    I can't find a good mobile printer (not a full size) that's also a scanner. Any recommendations?
  6. celticwolf
    celticwolf Road Train Member
    Oct 10, 2010
    1,527
    Thanks Received:
    642
    Kittrell, NC
    Canon has several. Look in Office Depot or Staples. Any printer with a USB port can be made wireless with the use of a wireless print server.
    The PS is much smaller than any converter I have ever seen. and can be velcro'd to a wall or the printer. My home PS is velcro'd under the printer stand.
    Just make sure you enable the wireless security or you might find me printing on your printer.. LOL
  7. statikuz
    Jun 22, 2009
    401
    Thanks Received:
    140
    Reno Nevada
    I assume by "full-size" you mean not a giant multi-function, something more single-sheet fed. I have not been able to find a combination mobile printer/scanner. Either you get two separate devices or you get an all-in-one and try to make room for it. There are a number of mobile scanners that are reasonably priced (Brother DS-600, Visioneer Road Warrior, Canon P-150) and also some mobile printers in the same form factor (Brother PocketJet 3) but that particular printer is a little spendy and only prints on special thermal paper. HP makes a compact printer (OfficeJet H470) as well.
    http://www.brother-usa.com/Mobile/ModelDetail.aspx?ProductID=DS600
    http://orders.visioneer.com/item.jsp?item=90-0527-000
    http://www.usa.canon.com/cusa/offic..._scanners/imageformula_p_150_portable_scanner
    http://www.brother.eu/g3.cfm/s_page/184170
    http://www.shopping.hp.com/webapp/s...able&product_code=CB026A%23B1H&catLevel=2
  8. Rollover the Original
    Rollover the Original Road Train Member
    Jul 1, 2009
    3,206
    Thanks Received:
    2,712
    Springfield,MO
    I have to ask: Are you an O/O? if you're a company driver go here http://www.newegg.com/Product/Produ...GNEFL050509-_-ScannerFlatbed-_-L0C-_-38111023 This is a scanner. As a company driver you really don't need a printer! As to why? I had an HP multi function printer/scanner and never used the stupid printer. Just scan the copy and email it to the company, or that is if they have anyone smart enough to actually know how to print from a jpeg or doc file! Some of these MORONS that think they're a business still rely on that scale shedding dinosaur called FAX!That is "soooo last century!"
    It's like I had to tell Trans Am when I had the misfortune to drive for them! They lost paper work like crazy! And then when called on it they wanted me to fax the copy and then would lose that receipt until I told them to either pay me or send me the cost of the copy and fax and a PO#. They figured out how to do it by email!
    Using the scanner all you have to do is scan to a file and then email the stupid file to them! No long distance charges, minutes charges, broadband/data cost of using the cell phone to fax that way and yes you can fax using a doc file!
    This one scanner takes up room in the laptop case, not a shelf! But if you so need a printer this is a new product out and looks promising for when you just got to have something printed AND it hooks up to some smart phones! IDK the price but all of the "portable" printers out there are a bit pricy but where space is a premium and if you need to "bail" from the truck taking these with you in your "one" bag should not be a problem. http://planon.com/products/printstik
    But all in all I would shy away from a $75 Printer/scanner as that's the loss of a whole shelf AND they don't take truck life well! I got lucky with one that lasted almost a year from the beating it took.
    I'd just scan and save and when a copy is needed you can stop at a Kinkos OR use the CB and ask if someone has a printer and put what you need to a flash drive and go use their printer. And do not go into panic mode about "viruses" on flash drives! If someone hands you a FD then scan it before you open it! If you have a half way decent virus program you won't have a problem as long as you do a daily update!
  9. statikuz
    Jun 22, 2009
    401
    Thanks Received:
    140
    Reno Nevada
    Agreed on the scanner - most will scan directly to a PDF and if there's something that office people love, it's PDFs. :)
  10. LindaLou
    LindaLou Light Load Member
    Jul 23, 2006
    149
    Thanks Received:
    85
    I use a Canon copier, scanner, printer. In a Volvo 780 it wasn't to bad on taking up space. When I have to T-Call a load (drop off in transit for another driver to continue with) I'm required to have a copy of the bills for my trip envelope. Sometimes finding a copier at 3 am isn't easy! Also, if I was picking up a load like that, I helped the driver dropping by making him a copy. If you can spare the room, the convience is good. I paid around $100 for mine and took the road fine, althought the ink is kinda pricy!
