My truck is bucking when taking offHelp.....
Discussion in 'Kenworth Forum' started by Maxxlights, Jan 8, 2012.
  1. Maxxlights
    Maxxlights Bobtail Member
    Oct 1, 2011
    12
    Thanks Received:
    4
    Montana
    Help..... I just bought a Freighter....
    Bobtail started out great.
    Empty side dumper when letting out in first gear as it engages it shudders a little till im rolling
    With 25 ton load on any kind of incline it bucks like crazy!!
    If I am on downward incline it starts out normal
    It seems to be getting slowly worse.... If I cant get moving you can see my problem. this is only starting from dead stop.
    All the trucks ive driven let out on steep incline and away they go.
    Whats worn?
    What needs adjustment?
    The clutch begins to engage about 1 inch of pedal push
    No grinding of gears going into gear.
    Linkage?? meaning clutch is not engaging soon enough take up some space??
    Help gotta move dirt again tomorrow
  2. bender
    bender Road Train Member
    Jul 20, 2010
    2,105
    Thanks Received:
    1,356
    Don't Kid Yourself
    Could be the way the truck is geared or clutch or combination of the two. What trans and diff ratio does truck have?
  3. king Q
    king Q Road Train Member
    Jul 26, 2010
    2,880
    Thanks Received:
    3,032
    Johannesburg sa
    Check out engine and gearbox mountings.
  4. aktundratugger
    aktundratugger Light Load Member
    Feb 10, 2012
    126
    Thanks Received:
    32
    up on the hill, Ak
    i had that same problem, my pressure plate was warped and my clutch was slipping and then grabbin and then slippin ect....
  5. LSAgentOZR
    LSAgentOZR Road Train Member
    Nov 1, 2011
    2,043
    Thanks Received:
    1,354
    Nashville, TN
    Don't use your spurs so much and show her a little love! :biggrin_25525:
  6. Stuskw
    Stuskw Bobtail Member
    Nov 9, 2011
    35
    Thanks Received:
    11
    BC Canada
    Like king Q said, sounds like your motor mounts are done. That was the problem with mine.
