N14 celect plus disrupted calibration.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Aussie jake, Oct 24, 2013.
  1. Aussie jake
    Aussie jake Bobtail Member
    Jan 29, 2012
    39
    Thanks Received:
    Melbourne victoria
    I was recalibrating a n14 celect plus today and the usb lead came out of my laptop and disrupted the calibration going in to the ecm. Now I can't connect to the ecm and engine will not start. Have I fried the ecm or does it need a reboot or something?
  2. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,771
    Thanks Received:
    6,210
    The ECM is now in a ROM boot state. Basically brain dead. It still should be able to connect and Insite should tell you the ECM is in an invalid state and is now ROM booted. It will need to be recalibrate again, but you may need to pay for calibration authorization password from Cummins since it is now blanked. Which version of Insite are you using?
  3. Aussie jake
    Jan 29, 2012
    39
    Thanks Received:
    Melbourne victoria
    Im using insite 7.4 pro plus.
  4. Heavyd
    Feb 4, 2009
    7,771
    Thanks Received:
    6,210
    I think with a rom booted ecm you can only connect to it with the key OFF. Try to disconnect battery power for about 5 min. Reconnect the batteries, leave the key off, and try to reconnect with Insite. You should be getting a message like, "Insite cannot communicate with the connected ECM because it is ROM BOOTED" or something like that. Then there should be a prompt to install a new calibration.
  5. Aussie jake
    Jan 29, 2012
    39
    Thanks Received:
    Melbourne victoria
    Worked out today ecm is fried. So lucky we found a secound hand one. Thank you for you replies.
  6. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    if ecm software is bad and cant be recalibrated with INCAL, I had to change internal memory chips. but empty wont working. I used memory dump files)
  7. Fang1
    Fang1 Bobtail Member
    Jan 29, 2014
    Thanks Received:
    What kind ECM? ISL ECM has only CYG2137VNLL-70ZSXE chip
