New Log Program (more friendlier)
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by LogsRus, Mar 15, 2009.
  1. LogsRus
    LogsRus Log it Legal
    Nov 23, 2006
    2,589
    Thanks Received:
    358
    Indianapolis, Indiana
    I am not in any way selling this to any driver however I am letting you know it's out there if you don't know already.
    If you couldn't use driversdailylog because it confussed you, this program is more like a log sheet. I don't like it "personally" as well as I do driversdailylog however it has the same purpose and works for those drivers who just want to fill it out on the computer simply. I should get paid for selling it, l.o.l. I believe it's cheaper I can't promise.
    There is one nice thing if your company uses the rapid log system (eclipse) the company can pay $1.50 per driver using it and download the logs (once DOT says it's ok to digitally sign the logs) once you have submitted them so no need to scan, mail or fax them if you are downloading them like you should!
    Anyhow thought I would help a driver out.
    Also they will take a copy of your companies log sheet so when you print it out it looks just like the log you would handwrite so all scannable systems should accept the logs however you need to discuss this and push this with your log auditor.
    It is legal by DOT and the company can use them in many cases however they believe they can't (like I did at one time). Just push it and you will see!
    http://www.logbook.com/Default.aspx
    Information above is only intended for you as a driver and you must talk with your company to make sure.
    If you fill out a log sheet and do it on the computer DOT can fine you for duplicate logs. :yes2557:
    ProPilot Thanks this.
